Arduino Voice / Speech Recognition With Geeetech Module [Tutorial]
Published
Introduction: Arduino Voice / Speech Recognition With Geeetech Module [Tutorial]
About: My name is Matthew and I attend the University of Pittsburgh. Currently I am a senior, going for a bachelors in Information Science with a minor in CS. Current interests include augmented reality, virtual re...
How to: Arduino Voice / Speech Recognition with Geeetech Module [Tutorial]. This video will show you how to talk with your Arduino with the (cheap) Geeetech voice control module. You can then use the code to control a motor or make voice controlled lights. There are a few videos that demonstrate the same thing, however they use a windows machine with Accessport, here I have used CoolTerm on a Mac to send Hex commands to the TTL module.
Code and parts links can be found here: www.WireBeings.com/voice.html
WINDOWS USERS:
This guy does a good job illustrating use with Accessport:
(I think he is using a different board though, and he doesn't send the final command (AA21) so don't forget to do that)
https://www.instructables.com/id/Arduino-voice-cont...
Step 1: Connections and Code
#include<Servo.h>
byte com = 0;
Servo myServo;
void setup() { Serial.begin(9600);
myServo.attach(9);
delay(2000);
Serial.write(0xAA);
Serial.write(0x37);
delay(1000);
Serial.write(0xAA);
Serial.write(0x21); }
void loop() {
while(Serial.available()) {
com = Serial.read();
switch(com) {
case 0x11: //command 1
myServo.write(0);
break;
case 0x12: //command 2
myServo.write(45);
break;
case 0x13: //command 3
myServo.write(90);
break;
case 0x14: //command 4 myServo.write(135);
break;
case 0x15: //command 5 myServo.write(180);
break;
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    Arrgghh -- I'm following along your very easy to follow instructable. I'm using windows, though. You say that windows will have no problem recognizing it when I plug it in. Maybe that's true -- but in Windows 10, even though it recognizes it, it gives a driver error. Apparently prolific-usb-to-serial-comm-port-windows is not supported in Windows 10. Supposedly you can try to load an older driver to get it to work, but I haven't had success with that yet.
