Waveform generators (also called function generators) are useful for testing and debugging circuits. I often use them to test the frequency response ...
The Arduino Proto Shields are a convenient way to attach circuits to an Arduino, but I like to trim them down a little bit first so they do not take u...
I decided to laser cut a custom enclosure for my project. I designed the enclosure using AutoCAD, Autodesk 123D Make, and Corel Draw, and I've includ...
Solder a 10kOhm resistor to one lead of each of the four push buttons. As shown in the second image, solder a green wire to the junction between the ...
Unscrew the plastic casing from the audio jack. Solder a red wire to the two stereo out pins and solder a black wire to the ground pin (fig 3). I us...
Solder a 10kOhm resistor to the protoshield so that one end is connected to the 10kOhm resistor attached to digital pin 0 and the other end is connec...
It's a good idea to use sockets for your ICs, this way you won't risk burning the IC with your soldering iron and you can easily replace the IC if it...
Use a resistor and capacitor in series to create a low pass filter. Low pass filters let low frequencies pass through and silence (attenuate) high fr...
Connect the positive lead of the 220uF capacitor to the junction between the resistor and capacitor of the low pass filter. The other end of the 220u...
Connect the positive lead of a second 200uF capacitor to pin 5 of the IC socket. The other end of the cap will be connected to the gain pot in a late...
Volume or gain of the audio signal will be controlled with the 10k audio taper pot with switch. Connect the audio out from the amplifier and ground t...
Connect the black wire from the battery clip to ground on the Arduino Shield. Connect one lead from the gain pot switch to the red wire from the bat...
Connect the output from the amplifier (the negative lead of the cap connected to the IC at pin 5) to the red wire we attached to the audio jack in an ...
Connect all read leads from the button to 5V and all the black wires to ground on the arduino shield (fig 1). Connect the green wires to analog in 0-...
Connect a red, black, and green wire to the 10kOhm and 50kOhm potentiometers as shown in the images. Connect the red lead to 5V and the black leads t...
Remove the side tab on all of the pots before installing in the enclosure, this will allow them to sit flush against the wood. Remove washer and nut ...
Attach a 470Ohm resistor to the cathode of each of the four LEDs. Solder a black wire to the other end of the resisotr and a red wire to the anode of...
Glue the LEDs in the enclosure so that they are each pointed towards one of the cutout symbols on the front panel. Here is a table for reference: di...
Upload the code at the bottom of this step onto the Arduino. The code uses a timer interrupt at a frequency of 100kHz to send new data out to the DAC...
Turn up the gain knob to turn on the function generator. Plug an eighth inch jack into the output and hook up the function generator to an oscillosco...
Waveform generators (also called function generators) are useful for testing and debugging circuits. I often use them to test the frequency response of electronics components like op amp and sensors. This waveform generator is powered by an Arduino. It outputs four waveshapes: sine, triangle, pulse, and saw, each waveshape ranges in frequency from 1Hz-50kHz. The frequency, pulse width, and overall amplitude (gain) of the waveforms is controlled by three potentiometers. I've also included (optional) indicator LEDs that let you know which type of wave is currently being sent to the output.
The Arduino Proto Shields are a convenient way to attach circuits to an Arduino, but I like to trim them down a little bit first so they do not take up so much room in the project enclosure. Start by trimming the pins down with a pair of wire cutters. Next, cut off the six pin socket. Finally, cut the sockets from the top of the board.
Step 2: Enclosure
I decided to laser cut a custom enclosure for my project. I designed the enclosure using AutoCAD, Autodesk 123D Make, and Corel Draw, and I've included corel draw and adobe illustrator 2D files as well as the STL, and DWG files from this process below. If you do not have access to a laser cutter, you can use my 2D files a guide and drill the necessary holes in a project enclosure of some kind. Figure 4 shows the holes that should be drilled on the front panel:
(3x) 7mm holes for gain, freq, and PWM pots
(3x) 7mm holes for four push buttons- sin, saw, tri, and pulse
(1x) 10mm hole for audio out
I cut out shapes of all four waveforms in the front of the enclosure so that I could backlight them with indicator LEDs, you may choose to just drill four 5mm holes for these LEDs in the front panel of the enclosure, place one LED under each momentary switch.
Also include a rectangular (11mm tall, 12mm wide) cutout somewhere on the side of the enclosure for the arduino's usb port.
I made my project enclosure out of wood, so I had to glue all the pieces (except the bottom) together with wood glue. I will attach the bottom panel on later in this instructable.
Solder a 10kOhm resistor to one lead of each of the four push buttons. As shown in the second image, solder a green wire to the junction between the button and the resistor and a red wire to the other end of the resistor. Solder a black wire the the second lead of the push button. It's a good idea to cover these connections with a bit of heat shrink to prevent short circuits (fig 2).
Step 4: Install Audio Jack
Unscrew the plastic casing from the audio jack. Solder a red wire to the two stereo out pins and solder a black wire to the ground pin (fig 3). I used hot glue to prevent short circuiting the jack and to give the soldering joints some extra support. Finally, mount the audio jack in the enclosure with super glue.
Step 5: Install Buttons
Snap the top of the button off and fit them into the wooden enclosure. Secure with hot glue. Once dried, snap the black button tops back on.
Step 6: R2R DAC on Arduino Shield: Part 1
Solder eight 20kOhm resistors to the arduino protoshield. One end of each resistor should connect to digital pins 0-7.
Step 7: R2R DAC on Arduino Shield: Part 1
Solder 7 10kOhm resistors to the protoboard so that they bridge the leads of the 8 20kPhm resistors you have just soldered.
Step 8: R2R DAC on Arduino Shield: Part 3
Solder a 10kOhm resistor to the protoshield so that one end is connected to the 10kOhm resistor attached to digital pin 0 and the other end is connected to a jumper wire to ground.
Step 9: IC socket
It's a good idea to use sockets for your ICs, this way you won't risk burning the IC with your soldering iron and you can easily replace the IC if it breaks. Solder an 8 pin socket to the protoboard as shown in the image.
Step 10: Low Pass Filter
Use a resistor and capacitor in series to create a low pass filter. Low pass filters let low frequencies pass through and silence (attenuate) high frequencies. Connecting a low pass filter to the output from the dac will smooth out the steps in the wave.
Here's how I calculated the value of the components in my low pass filter:
corner frequency = 1/(2*pi*R*C)
According to Nyquist's Theorum, signals cannot contain frequencies higher than half their sampling rate. If I used a sampling rate of 100kHz, then the highest frequency I can produce is 50kHz.
if I use a 300Ohm resistor and I want a corner frequency of 50kHz:
50000 = 1/(6.28*300*C)
C = 1.06*10^-8 F
round this to:
C = 0.01uF
Connect one end of the the 300Ohm resistor to the 10kOhm resistor connected to digital pin 7. Connect the capacitor to the other end of the 300Ohm resistor. The other side of the cap should connect to ground.
Step 11: Amplifier: Part 1
Connect the positive lead of the 220uF capacitor to the junction between the resistor and capacitor of the low pass filter. The other end of the 220uF capacitor connects to a 20kOhm resistor that is connected to pin 3 of the IC socket. A 4.7kOhm resistor bridges pins 3 and 4 of the IC socket.
Step 12: Amplifier: Part 2
Connect ground to pin 4 of the IC socket.
Step 13: Amplifier: Part 3
Connect the positive lead of a second 200uF capacitor to pin 5 of the IC socket. The other end of the cap will be connected to the gain pot in a later step.
Step 14: Amplifier: Part 4
Connect pin 6 of the IC socket to Vin, pin 2 to ground, and snap the IC into the socket.
Step 15: Wire Gain Pot
Volume or gain of the audio signal will be controlled with the 10k audio taper pot with switch. Connect the audio out from the amplifier and ground to either side of the potentiometer as indicated in the picture. The middle is audio out, it will be hooked up directly to the audio jack.
Also connect a wire to the bottom and left leads on the back of the pot (figure 2). This is the switch that will be used to connect to power in the next step.
Step 16: Connect to Battery
Connect the black wire from the battery clip to ground on the Arduino Shield. Connect one lead from the gain pot switch to the red wire from the battery clip and connect the other gain pot lead to Vin on the Arduino Shield.
Leave the battery disconnected for now.
Step 17: Connect Output to Headphone Jack
Connect the output from the amplifier (the negative lead of the cap connected to the IC at pin 5) to the red wire we attached to the audio jack in an earlier step. Connect the black wire from the audio jack to ground on the Arduino Shield.
Step 18: Wire Buttons
Connect all read leads from the button to 5V and all the black wires to ground on the arduino shield (fig 1). Connect the green wires to analog in 0-3 in the following order:
analog 0 = pulse
analog 1 = triangle
analog 2 = saw
analog 3 = sine
Step 19: Wire Frequency and PWM Pots
Connect a red, black, and green wire to the 10kOhm and 50kOhm potentiometers as shown in the images. Connect the red lead to 5V and the black leads to ground on the arduino shield. Connect the center green wires to analog pins 4 (PWM) and 5 (frequency).
Step 20: Install Pots
Remove the side tab on all of the pots before installing in the enclosure, this will allow them to sit flush against the wood. Remove washer and nut from each of the pots, place pot through hole in enclosure, and secure with nut. Install all three pots in the enclosure.
Step 21: Wire LEDs: Part 1
Attach a 470Ohm resistor to the cathode of each of the four LEDs. Solder a black wire to the other end of the resisotr and a red wire to the anode of the LED. Cover these connections with shrink wrap to prevent short circuiting.
Step 22: Wire LEDs: Part 2
Solder the black leads from all four LEDs to ground on the arduino shield. Solder the red leads to digital pins 8-11.
Step 23: Black Diffuser
Glue a light diffusing material behind the wave cutouts in the front panel. I used a piece of a black plastic garbage bag.
Step 24: Glue LEDs
digital 8 = pulse
digital 9 = triangle
digital 10 = saw
digital 11 = sine
Step 25: Firmware
Upload the code at the bottom of this step onto the Arduino. The code uses a timer interrupt at a frequency of 100kHz to send new data out to the DAC. The rest of the code monitors the state of the buttons and knobs and adjusts variables accordingly. Since the interrupts occur at such a high frequency, I had to keep the interrupt routine, the piece of code encapsulated in the ISR(TIMER1_COMPA_vect){} as short as possible. Time intensive operations like mathematical operations with floats and using the sin() function take too much time to complete. I used several work around to get by this:
For triangle and saw I created the variables sawByte, triByte, sawInc, and triInc. Every time the frequency changed I calculated the amount that the triangle and saw function would have to increment at a sampling rate of 100kHz:
triInc = 511/period;
if (triInc==0){
triInc = 1;
sawInc = 255/period;
if (sawInc==0){
sawInc = 1;
then all the needed to be done in the interrupt routine was some simple math:
case 2://saw
if (t=0){
sawByte=0;
else{
sawByte+=sawInc;
wave = sawByte;
break;
For the sine function, I wrote a simple python script which outputs 20000 values of 127+127sin(x) for one complete cycle:
import math
for x in range(0, 20000):
print str(int(127+127*math.sin(2*math.pi*x*0.00005)),)+str(","),
I stored this array in the Arduino's memory called sine20000[] and recalled the values I needed to send to the DAC. This is much faster than calculating the values individually.
Plug the Arduino into your shield. Connect a 9V battery to the battery clip. Secure these items inside the enclosure. Make sure that the Arduino's usb port is accessible from the outside of the enclosure. Upon startup you should see the sine wave LED light up.
Step 27: Screw Back Panel
Drill four holes in the back panel and secure with screws.
Step 28: Add Knobs
Screw knobs on the three potentiometers.
Step 29: Test
Turn up the gain knob to turn on the function generator. Plug an eighth inch jack into the output and hook up the function generator to an oscilloscope. Test out each of the waveforms and adjust the frequency and gain to make sure they are working properly. Switch the output to pulse and check if the pulse width modulation knob works (figs 4-6).
You will notice that the pulse wave is the only wave which truly ranges from 1Hz to 50kHz. Since the sampling rate is 100kHz, the sine, triangle, and saw waves start to become somewhat unrecognizable at about 25kHz (they are only comprised of 4 samples per cycle- 100kHz/25kHz). The saw and triangle waves only go down to about 100Hz, this is because the values of triInc and sawInc get so low that they are rounded to zero below this frequency. The sine wave reaches all the way to 1 HZ but the resolution stays the same for anything under 5Hz, since the Arduino only has enough memory to store about 20 thousand samples.
There are numerous errors in the instructions that deviate from the schematic and a few errors in the instructions themselves. First, there should be a 20k resistor used in step #8 instead of a 10k resistor. This was the first time I ever had to desolder something in my life and it was a pain. Second, the green wire was never used in step #17. Please fix them!
How can one make this able to drive a flyback transformer. I know there is a way to do it, a vid of a guy on youtube does it but doesn't show how. I ordered a DDS function generator and just cant put 2 and 2 together to figure out how to drive a flyback with it and I would like to be past this.. simple set back.
lots of things, mostly testing the frequency response of circuits, response time of components... something like this: http://www.instructables.com/id/Oscilloscope-How-To/step9/Advanced-Oscilloscope-Dual-Channel-Measurements/ anything you would need an oscillating signal to measure.
It is a very nice project but its a bit overkill to use an arduino for a functiongenerator that will be patched in a soundgenerating system (aka a synth.)
Even if you would use a microcontroller, an attiny would be a better choice I guess (you can use your arduino to program these).
On the other hand, if you go a bit bigger and use an atmega32 you could make an entire synth with it. Have a look at the Meeblip website (meeblip.com)
I hope not to detract from this great instructable, but if you want an arduino based audio synth you might also consider the GinSing shield ( www.ginsingsound.com ).
great work !! i was wondering to make arduino read a sine wave from 12VAC transformer. i want to get data every sample that been generated..can i give me idea..can u guide me pls
the numbers actually aren't related. I chose 20000 values for the sin function bc I could fit that many numbers in the Arduino's memory and it helps to increase the resolution of the signal. I chose the 100kHz sampling rate so that I could easily reproduce signals through the audible range (~20hz to 20kHz). at 100kHz sampling rate, I can get 100/20 = 5 samples per cycle on a 20kHz signal.
Hi Amanda. Is there a simple way to generate a sin wave from the arduino ? I want to have a signal which contains two or three frequencies. I thought about generating a few sin wave with the arduino then multiply or sum them.
Hi Amanada. thanks for writing so many wonderful tutorials, its a pleasure following your tutorials, they are clear, and well thought of! I am building a game for kids with which we can demonstrate breaking glass in classroom. I wanted to know if you can add directions on how to create a sine wave with a resolution of 1/10 Hz - for example ,I need to be able to tune the generator to 1000.03 Hz. should I use a second potentiometer to get better resolution? and in the Arduino code itself, what should needs to be change for the sine wave section?
you need to change this line: frequency = freqCurrent;//new frequency- number between 0 and 1024 freqscaled = 48*frequency+1;//from 1 to ~50,000 get it so that freqscaled is in the range you want, maybe 999 to 10001Hz for values of frequency that range from 0 to 1024 also change: int frequency; int freqCurrent; unsigned int freqscaled; to float frequency; float freqCurrent; float freqscaled; that should work, let me know if you have trouble
im using an arduino clone. how should i connect the components to the micro controller? should i wire the PD,PB,PC to its PB, PB, PC counter part using the schematic of the clone? TIA
Is the resistance (R21) between ground and the r2r-ladder 10k or 20 k. In the schematic it is 20k, but in the description it is 10k. I don't know, what' right ,
The Arduino's own processor limits the maximum step speed, which constrains the wave frequency. The Arduino's processor frequency internally is 8MHz, while the on-board 16MHz oscillator allows each step to occur at the faster rate. If a full wave takes 16 steps, then the maximum frequency of the output (ideal) would be 1MHz but resolution of the waveform would suffer. In the provided sketch, the triangular waveform is stored in an array using (127+127) increments per cycle, so the maximum (ideal) frequency would be roughly 125kHz. In addition, the low pass filter that smooths out the wave output also constrains the operating frequency based on the discharge rate of the cap, so that the provided cap and resistor values operate under 100kHz..
Hi Amanda.! it's exelent you project .. I just wanna know, where I can find the full schematic.. Do you think that can help me with that ? thank you very much..
amanda. it is so nice instruction. i was looking interrupt for Arduino few month. but not easy to find good instruction. your's is best. thank you. i put this interrupt function to my open hardware brain wave interface project. works nice. but can not do many things in the main loop and inside of interrupt anyway. mean can not set sampling frequency to high. but that is ok for usually. also can not use Analogue write function. can use hardware interrupt then can use Analogue write but processing time problem is same. specially analog read takes time. currently processing to make document for my project. let you know then.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
The code can not be uploaded on my Arduino Mega. But other codes function properly. Are there any special things I need to know?
http://www.instructables.com/id/Arduino-Audio-Input/
Why you choose 20000 values on the sin function? and why the sample rate is 10000?
Thanks =]
Thank you
http://www.instructables.com/id/Arduino-Audio-Output/
thanks,
Eran
also change:
int frequency;
int freqCurrent;
to
float frequency;
float freqCurrent;
float freqscaled;
http://arduino.cc/en/Hacking/PinMapping168
it's a wonderfull project !
i have one question:
thanks
http://en.wikipedia.org/wiki/Resistor_ladder
Ah - you're writing a string - and you copy and paste that into your Arduino script?
sine20000[] = [copy & pasted python output here]
