Arduino Weather Station (AWS)
142,649
980
79
Posted
Introduction: Arduino Weather Station (AWS)
In this project, we will be making a weather station that measures air pressure, temperature, rain drop, soil humidity and air humidity using Arduino which save the data for data acquisition!
It’s a fairly easy project and can be used either on its own or part of something bigger, check it out >> Integrated Weather Station (IWS).
Step 1: List of Material
For this project, we will be using:
- Arduino boards (mine Arduino Uno Rev3)
- DHT11 Humidity and temperature sensor cost: ~5.00 USD
- BMP185 Barometer sensor cost: ~6.00 USD
- Rain Drop sensor module cost:~2.00 USD
- Soil Humidity sensor module cost:~2.00 USD
- Breadboard or Custom ProtoShield (Check it out how to make it >> )
- Jumper Wire
Step 2: Hardware Connections
In general, the connections are very simple. Follow the instructions and images above, and you should have no problems.
Connecting Rain Drop Module
  • the VCC pin on Arduino’s 5V output
  • the GND pin to Arduino’s GND and
  • the Analog Data to Arduino's analog pin 0
Connecting Soil Humidity Module
  • the Analog Data to Arduino's analog pin 1
Connecting BMP185
  • the VCC pin on Arduino’s 3.3V output
  • the SDA (Serial Data Line) pin to Arduino’s analog pin 4 and
  • the SCL (Serial Clock Line) pin to Arduino’s analog pin 5
Connecting DHT11
  • the DATA pin to Arduino’s digital pin 4
Step 3: Arduino Programming
Below is the Arduino Weather Station code. Include the library from AWS_library.rar, upload the code to your Arduino (Mine Arduino Uno Rev3), and you should have no problems.
You can clone and edit the code in any way you prefer.
Step 4: Enjoy!
Power through batteries or a plug and you’re good to go.
After making sure that everything works smoothly, you can take this project into bigger project. Check it out >> Integrated Weather Station(IWS) !
2 People Made This Project!
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
Hello,
How are you doing???
Has ANYONE installed an LCD, or thought about installing a mini-LCD to this project?
If so, PLEASE contact me.
Let me know.
I look forward to hearing from you..
69 Comments
hi i build this project but i want to add an LCD screen how to edit the program?
add an I2C LCD to I2C pins, include the proper library, create lcd object and use 'lcd.print'
Hello,
I just made a request, for this information.
Is it possible for you, to allow me view your notes, and apply your schema>
Let me know (tptbusines_98@yahoo.com).
I look forward to hearing from you...
How to send attach a PIR sensor and DHT11 Humidity and temperature sensor in audrino and send the status of these sensors to an android app via bluetooth.
PLEASE help me
attach PIR sensor to free digital pin and read the status. Attach a bluetooth module to the Serial port and use a bluetoot terminal app on your phone to read the data.
There already is a DHT11 sensor
i want to send the output to my mobile via wifi can anyone tell about it
add a wifi card. or better yet, ditch the ArduinoUNO and use an ESP8266
where we will be getting output results? on laptop or we need any lcd display?
what to do if we don't want pressure sensor in circuit?
There is a pressure sensor in the circuit: the BMP180.
Judging from the program the output is sent to the console
