Arduino Weather Station || DHT 11
Published
Introduction: Arduino Weather Station || DHT 11
About: TechMaker is a channel loaded with awesome Electronics Tutorials, Projects and How To´s using Arduino's
I build a Arduino Weather Station. It uses a DHT 11 ( it will also work with DHT21 DHT22)
Step 1: Video
I also explain everything in this video. So it might be easier for you if you watch it!
Step 2: First Sketch
The first sketch displays the sensor values to the Serial Monitor
  • Sensor:
pin 1 - 5
pin2 - 5v
pin3 - GND
Step 3: Second Sketch
In this sketch we are going to display the values onto an Lcd. I used a i²c lcd for this project.
  • Sensor:
pin 1 - 5
pin2 - 5v
pin3 - GND
  • LCD:
SDA - A4
SCL - A5
GND - GND
VCC - 5V
Step 4: Third Sketch
The final sketch also displays a realtime clock to the lcd. It uses a DS1302 module. For more information about this clock you can check out the Arduino clock I made in a previous project.
  • Sensor:
pin 1 - 5
pin2 - 5v
pin3 - GND
  • DS1302
RST - 2
DATA - 3
CLK - 4
  • LCD:
SDA - A4
SCL - A5
GND - GND
VCC - 5V
Step 5: Code
Libraries are in a map. You have to first unzip the map. Then install them
First sketch
Upload the sketch: TEST
libraries needed: Adafruit_Sensor-master, DHT-sensor-library-master
Second sketch
Upload the sketch: LCD
Libraries needed: NewliquidCrystal, Adafruit_Sensor-master, DHT-sensor-library-master
Third sketch
Upload the sketch: LCDCLOCK
Libraries needed: DS1302, NewliquidCrystal, Adafruit_Sensor-master, DHT-sensor-library-master
Step 6: Subscribe
If you want to see more of mine projects you can subscribe to my YouTube channel! Here is the link: https://www.youtube.com/c/TechMakerOfficial
    • Oil Contest
      Oil Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
