loading
Step 2: Rain Gauge Design
Problem: How to design a tipping bucket rain gauge.
Solution: So I did some research on tipping buckets. How they work is that the funnel is over one of the buckets. Rain drips into the funnel and into one of the buckets. After a certain amount of water, the weight of the water tips the bucket so the other bucket is under the funnel and the reed switch is triggered and sends a count to the circuitry. As the rain continues, the other bucket fills up and tips it the other way again triggering the reed switch.
To make my tipping bucket, I took a piece of the aluminum ‘NoTrespassing’ sign, I used for my weather vane. I marked a rectangular piece 3” x 2.25” as shown in the diagram. I cut it with a pair of scissors and folded up the sides. I happened to have a piece of ¾” aluminum, I used to shape the trough and bent the sides up. Then I trimmed the sides so they were triangles. I cut another aluminum piece ¾” square, rounded the bottom corners and hot glued it in the middle so that you have two ‘buckets.’ See first picture.
Warning: If you are a horrible hot-gluer like I am, it might leak. Mine did. Pour a little water in the side tilted up and see if it leaks out the other side. If it does, heat up the joints and/or add more hot glue. You can see from my pictures what a terrible job I did but it stopped leaking.
The next picture looks a little weird. I wanted to use nylon spacers for the pivot point but my local Ace hardware didn’t have any. They did have these #8 nylon washers that are about 1/8” thick so I bought them. I wanted the spacers to stick out away from the sides of the tipping bucket so I taped another scrap of the sign to the tipping bucket then I tapped the washer so that it was flat with the scrap. The adhesive tape looks pretty weird in this picture. Then I hot glued the washer to the bottom of the bucket assembly and did the same to the other side.
The next picture shows the results. Again you can see my poor hot-glue skills and yes, it’s a little crooked but it worked okay.
<p>You are are a genius! Wonderful project!</p>
<p>Hello, can you help me to make my own wind sensor, and can you suggest a CO2 sensor that can connect to the arduino ? I'm trying a project on weather station for climate researchers, thanks</p>
<p>Here's how I made this wind speed sensor:</p><p><a href="https://www.instructables.com/id/Arduino-Wind-Chill-Machine/">https://www.instructables.com/id/Arduino-Wind-Chill...</a></p><p>Never used a CO2 sensor but found some on ebay like this one:</p><p><a href="http://www.ebay.com/itm/CO2-Carbon-Dioxide-Sensor-with-Analog-Signal-TTL-Level-Temperature-Output-/271664310826?hash=item3f40746a2a:g:7O0AAOSwgQ9Vqci3">http://www.ebay.com/itm/CO2-Carbon-Dioxide-Sensor-...</a></p><p>LOG</p>
<p>Hello! Could you help me to make my own rain gauge? I'm a Brazilian Agronomist Engineer, and don't understand about eletric things... I have problems to learn which are the pieces to make this work... Thanks!</p>
<p>It's a little hard to explain. The magnet is attached to the tipping bucket. As the rain fills one bucket, the bucket tips and the magnet passes by the hall effect sensor. Then more rain fills the other bucket and flips the magnet past the sensor in the other direction. In one direction the hall effect puts out a low voltage (0 volts), in the other direction a high voltage (5 Volts). So what I do is count the transitions to see how many times the bucket tips.</p><p>Hope this helps.</p><p>LOG</p>
<p>You have used only a hall effect switch and a simple magnet?</p>
<p>Electrically, that's all. The Arduino just counts the transitions.</p><p>This could also have been done with a magnet and a reed switch.</p><p>LOG</p>
<p>Thanks a lot!! My problem is in understanding the install of the sensors, because I don't know this parts and because of the translation (the translation in portuguese to technical words is not good). Now I'll try to understand and buy them. hugs</p>
it might be better to use caulk instead of hot glue when making the tipping bucket.
<p>You're probably right. But after several years, the hot glue seemed okay but the lid of the cashew nut container actually disintegrated. </p><p>LOG</p>
Wow lol
<p>I'm asking about the calculation of rain gauge.</p><p>You wrote Pi.r2 and that was an equation for circle's area.</p><p>Why don't you find out the area of that funnel itself? as i know you should find out the area of the funnel, not only the circle shaped of the funnel.</p><p>Anyway i dont really know do my statement is true but it is just my opinion.</p><p>and can i get any source of where you did get those equations from?</p><p>Thank you very much</p>
<p>The way I look at it is to visualize the rain as a flat sheet of water. The water that strikes the top of funnel is a circular disk. You actually want to know the height of the disk. So all of the water in that circular disk is measured by the buckets but to calculate the height you need to know the area of the circle.</p><p>Hope this helps.</p><p>LOG</p>
Amazing job , your recomended my project thanks
<p>It looks to me like you do not need the funnel as the down side is always draining up the the point where the weight of the water in the filling side tips the balance. </p>
<p>You could certainly try it but I don't think it would work. If the rain was falling evenly, pretty soon the buckets would be balanced and not tip either way. Practically speaking it's not going to be balanced but it would not be measuring the actual rain. One of the functions of the funnel is to direct all of the rain into the upper bucket. </p><p>LOG</p>
<p>Hi LOG: Having thought about it, I think you can throw the funnel away. The only time it would make a difference to a reading is when the rainfall over the left collector was different from that over the right collector. That should never be the case provided both collectors are out in the open.</p>
Wow! Amazing job, this an absolutely fantastic tutorial, as you can probably tell from the views. I'm sure you're thrilled. Views and likes are higher than ever! Especially on this wonderful DIY! Nice job
<p>Thanks, I appreciate it.</p><p>LOG</p>
<p>hello msuzukki777 . do you have whatsapp? i'want ask u something about your rain gauge .</p>
I do not have whatsapp.<br><br>LOG
<p>ok thanks. i want ask u something about rain gauge calibration because i do this project for my final year project . did the volume of bucket is fix with 5ml for rain gauge ? thanks .</p>
<p>The volume of the bucket is not fixed at 5ml. What I did was take the syringe filled with water and started dripping water into the bucket When it tipped, then I subtracted the amount left in the syringe from the full amount. It was just a coincidence that it came out to 5ml. I think adjusting the two screws had a slight affect on the volume also.</p><p>LOG</p>
<p>okay thanks for your information . by the way , can i replace the calibration screw with proximity sensor ? i want replace it because i think if the bucket tap the sensor , it will send the data to visual basic , can ?</p>
<p>Good idea. I think that should work.</p><p>LOG</p>
<p>@msuzuki777. sir , did you know how to communicate between hardware and software ? example , i want to communicate the sensor with visual basic but i have a problem . </p>
<p>What I do with this weather station is leave the Arduino attached to the computer. I used to be good at VB programming but the newer versions are harder (and I'm older). Basically, you have to add a serial port object(?) and connect it to the com port # that the Arduino is on. Then you have to parse the data string from the Arduino into the various variables.</p><p>Hope that helps.</p><p>LOG</p>
<p>in what way do the calibration screws -when raising- increase the amount of water needed to tip the bucket??<br>I would guess that the amount of water to tip a bucket is the same, the screw just determines how far the bucket (on that same side) will tip</p>
<p>Well, I'm not really sure but I think the screws change the tilt of the buckets. When water is added to the bucket, if the tilt is pretty small, the water will extend farther from the center and weight will tip the bucket sooner. It's the teeter-totter effect where the force is dependent on the weight and where along the buckets it is distributed. </p><p>LOG</p>
<p>perhaps. i was thinking along those lines too but i cant really picture it, you may and up with a bucket see saw that hardly can move anymore. Guess i have to build one and see :-)</p>
<p>If I have a different diameter for my collecting funnel, can i still use these formula to calculate the amount of rainfall?</p>
<p>Sorry I missed this comment. Yes, you can use the same formula by just changing the Radius value. (Radius is 1/2 diameter)</p><p>LOG</p>
<p>Hi sir, what kind of output has the ss461c?</p>
<p>It is a digital output. When it sees one polarity (N?) of the magnet it goes high. It stays high until it sees the opposite polarity (S?). Since I'm using 5Vdc, it is either 0V or 5V.</p><p>LOG</p>
<p>Do anybody know how to do the GUI in MATLAB or can you please help or teach me how to do it in VB? Need help! :( Thank you!</p>
Sorry,<br><br>Learning VB Express is pretty hard. I've been programming VB for probably 20 years and still have trouble. There are some tutorials but I doubt if they would help. E.g.,<br>http://msdn.microsoft.com/en-us/library/dd492171.aspx<br><br>I think you can do it if MATLAB but I don't have any experience with it.<br><br>LOG
<p>Really excited with this project.</p><p>Anyway, i'm going to integrate this system with a server. it was located miles away from the place where i place this system. So how can i do that?</p><p>Is it possible to send the read data using GSM modem and log it every 10 minutes?</p><p>Or maybe is there another way to do that?</p><p>thank you</p>
<p>I don't know how you could transmit/receive over several miles. You're probably right about using a GSM module but I have no experience for doing that. </p><p>You will also have to have a power source at the weather station.</p><p>LOG</p>
<p>Nice project ! I'm going to use this project for school :)</p>
<p>this is great inspiration .. i have been duin it as a part of my final year project..</p><p>can u please post or send me the new code u use...</p><p>thank you..........</p>
<p>Sorry, I don't have any newer code that will work with this setup.</p><p>LOG</p>
<p>That mountain in the background looks very familar. Might that be somewhere near the Coachella Valley in California?</p>
<p>No, it's in Colorado.</p><p>LOG</p>
<p>5mm seems like quite a large step - it must be quite common in a lot of areas to just get 1-5mm, and then have a sunny day. Since your remaining moisture is sitting in a metal cup in a greenhouse, I imagine a lot of it would evaporate in that situation, and you'd get a bias against low rainfall days. I imagine you could go a *lot* smaller without many problems cropping up.</p>
<p>I'm not sure where you got 5mm. I know I talked about 5mL as my bucket volume. But rain is measured in length(height) like inches or mm. The way I calculated it is that the volume of water hitting the bucket is the diameter of the funnel times the height of water. </p><p>As shown in step 8, the 5mL bucketful translates to 0.0128 inches of rain which is about 0.325 mm.</p><p>This is plenty accurate for me. </p><p>But you are correct that the accuracy could be increased with a smaller bucket size or what I would do would be to increase the funnel diameter.</p><p>LOG</p>
<p>Hello!</p><p>Your design is great, nice work! I'm working on a similar project but I'm a little strapped for time so I am trying to avoid ordering parts. Right now I'm working on the rain station and I'm wondering if you think that the SS345PT/SS445P is a suitable replacement for the SS361? the 361s are designed to respond to alternating North and South poles while the 345/445 responds to a single pole. I don't think I should have to change your design at all.. Any ideas?<br>I was also considering using a Hall Effect Sensor, but I'm not sure.<br>Much appreciated,<br>-V</p>
<p>My concern is that I don't think the SS345PT/SS445P are latching sensors. My sketch is designed to look for a high state than count only when it sees a low state. I believe these sensors only transition when the magnet is near but then returns to it's inactive state. </p><p>If my sketch was able to catch every toggle, then I suspect the count would be doubled actually. If it missed some toggles than the rain count would be less than actual.</p><p>LOG</p>
<p>A quick question. In all three parts, a few of the same parts. Did you purchase three sets of these, or are you listing them for people who only want to make the one part?</p>
<p>The parts lists are confusing if you read all of my Weather Station Instructables. Some, mainly the Arduino and data shield are duplicated. Only one of each is needed.</p><p>By the way, I'm still using my weather station but replaced the data logging shield with a custom PCB and eliminated the SD card as I never used it that much.</p><p>LOG</p>
About This Instructable
169,414views
321favorites
License:
Bio: Lazy Old Geek
More by msuzuki777:Senior Moments Weather Station 5 IP Time Clock Part 2
Add instructable to:
