Arduino Web Server
7,255
53
11
Posted in TechnologyArduino
Introduction: Arduino Web Server
About: I am a diy fanatic. I love to build electronics and play with computers. Me and my friends build projects together all the time. It is a great hobby and you should get into it too!
This project uses an Arduino ethernet shield to serve up a webpage to your router. When you connect to that webpage with your computer or mobile device, you can control the LED on the breadboard. Lets get started. (Update: The code and schematic came from Rui Santos at http://randomnerdtutorials.com/arduino-webserver-with-an-arduino-ethernet-shield/ )
Step 1: Parts
For this build you will need:
1x Arduino Uno R3 RadioShack
1x Arduino Ethernet Shield Amazon
1x Breadboard RadioShack
1x LED RadioShack
1x 220ohm Resistor RadioShack
You will also need:
Ethernet Cable Amazon
USB A to USB B Cable Amazon
Arduino IDE Arduino.cc
Hookup Wire
Step 2: Easy Assembly
Connect the ethernet shield to the Arduino by simply lining up the pins and pushing it in. Connect the led + pin to pin 3 on the Arduino. Connect the led - pin to the 220 ohm resistor. Connect the other end of the 220 ohm to the Arduino's GND. Use the image to help.
Step 3: The Code
This is the code for the project. The gateway, ip and subnet need to be changed to match you network. The MAC needs to be specific to the Arduino but do not change the "DE" at the beginning. Make sure no other device is using that MAC. (Update: Modified code to give credit to original creator.)
Step 4: Testing and Trobleshooting
When you connect to the webpage at 192.168.0.178, you should see the same as the image above. If the page doesn't load, push the RESET button on the Arduino and try again. If it still not working, check the gateway, the routers address, the subnet, and the MAC. If it does load, when you click lamp on, the led should come on. If not, check that the LED's longer pin is connect via hookup wire to Arduino pin 2. If anything is still not working, feel free to leave a comment.
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Make it Move Contest
11 Comments
Great project, thanks for sharing
I am not sure what you ment ? Arnt you still in LAN not in WAN?
Can this be all ? I am still Curius! can you Please explain more about It ?
"In the code, change the port 80 to 8081.
When you connect on the browser, enter this:
192.168.0.178.8081 (Arduino IP)Dot(Port)
If you have any issues, please let me know."
For LAN, keep the configuration that is in the code. If you would like to set it up for WAN, change the code and setup port forwarding as I described in other comments.
i made It !
Thanks ! it was a intresting and nice tutorial.
I am not to good in english language but i try my best!
IaI
The port forwarding should be setup like this:
Lan IP: 192.168.0.178 or Whatever your Arduino's IP is.
Protocol: TCP/UDP
Ports Forwarded: 8081
Remote Ports: 8081
This would work anywhere in the world as long as you have internet connectivity.
how change code to make that from other internet conection people could connect ? port fowarding already done
