Introduction: Arduino Wifi Temperature Logger
This is a simple demo using the ESP8266 and Cactus Micro (a arduino compatible board) to update a remote server (https://data.sparkfun.com/) using a digital temperature sensor.
Step 1: Materials
The Cactus Micro is an arduino compatible dev board, it integrated a WIFI chip ESP8266.
Step 2: Connecting the Wires Together
  • Connect esp8266 module is easy. Just plug in to the pins.
  • DS18B20 - DQ(2) -> Cactus pin 14, DQ(2) -> 4.7KR -> VCC(3.3V)
Step 3: Arduino Setup and Sketch
The sketch code: https://github.com/AprilBrother/cactus-micro/blob/...
For Cactus Micro Rev2, the default firmware for esp8266 is espduino. Please use this sketch instead. https://github.com/AprilBrother/cactus-micro-r2/tree/master/libraries/CactusMicro/examples/temperatureLogger
Step 4: SparkFun Setup
We create a data stream at SparkFun, follow this link to do this. https://data.sparkfun.com/streams/make
Once you've created your stream, keep the window open so you have easy access to your public and private keys handy - you'll need those to replace the KEY in the Arduino sketch.
Now you are ready to start sending data.
