Step 1: Construction
Step 2: Circuit
From the Wii nunchuck the yellow clock wire goes to analog in pin 5. Green data wire to analog in pin 4. red wire to 5v power via the breadboard with all the other power jumpers from the servos and white to ground.
9v battery to "vin" pin via an on/off switch.
The laser is not controlled by the Arduino. It is simply a laser attached to 3v battery pack via an on/off switch.
Step 3: Arduino Sketch
#include
#include
#include
#include
Servo myservo; // create servo object to control trigger servo
int pos = 90; // variable to store the trigger servo position
uint8_t outbuf[6];
int cnt = 0;
int ledPin = 13;
int servoPin = 7;
int servoPin2 = 6;
int pulseWidth = 0;
int pulseWidth2 = 0;
long lastPulse = 0;
long lastPulse2 = 0;
int z_button = 0;
int c_button = 0;
int refreshTime = 70; //tweaked for FutabaS3003 servos
int minPulse = 600; //tweaked for FutabaS3003 servos
int minPulse2 = 600; //tweaked for FutabaS3003 servos
int maxPulse = 2400; // maximum servo position
int maxPuls2e = 2400; // maximum servo position
int dtime=10;
#define pwbuffsize 10
long pwbuff[pwbuffsize];
long pwbuffpos = 0;
long pwbuff2[pwbuffsize];
long pwbuffpos2 = 0;
void setup()
myservo.attach(8); // attaches the trigger servo on pin 8 to the servo object
Serial.begin (9600);
Wire.begin ();
nunchuck_init ();
pinMode(servoPin, OUTPUT);
pinMode(servoPin2, OUTPUT);
pulseWidth = minPulse;
pulseWidth2 = minPulse2;
Serial.print ("Finished setup\n");
void nunchuck_init()
Wire.beginTransmission (0x52);
Wire.send (0x40);
Wire.send (0x00);
Wire.endTransmission ();
void send_zero()
Wire.send (0x00);
int t = 0;
void loop()
t++;
long last = millis();
if( t == 1) {
t = 0;
Wire.requestFrom (0x52, 6);
while (Wire.available ()) {
outbuf[cnt] = nunchuk_decode_byte (Wire.receive ());
digitalWrite (ledPin, HIGH);
cnt++;
if (cnt >= 5) {
int z_button = 0;
int c_button = 0;
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
switch (c_button) {
case 1:
muovi( outbuf[3] ,outbuf[2] );
break;
case 0:
muovi( outbuf[1]/2+0x3E ,outbuf[0]/2+0x3E );
break;
switch (z_button) {
case 0:
for(pos = 90; pos >= 120; pos += 1) // fires trigger when Z button pressed
myservo.write(pos);
delay(15);
for(pos = 120; pos >= 90; pos -= 2) // returns trigger to center
myservo.write(pos);
delay(15);
break;
case 1:
break;
cnt = 0;
send_zero();
updateServo();
delay(dtime);
void updateServo()
if (millis() - lastPulse >= refreshTime) {
digitalWrite(servoPin, HIGH);
delayMicroseconds(pulseWidth);
digitalWrite(servoPin, LOW);
digitalWrite(servoPin2, HIGH);
delayMicroseconds(pulseWidth2);
digitalWrite(servoPin2, LOW);
lastPulse = millis();
int i=0;
void printNunchuckData()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2];
int accel_y_axis = outbuf[3];
int accel_z_axis = outbuf[4];
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print (i,DEC);
Serial.print ("\t");
Serial.print ("X: ");
Serial.print (joy_x_axis, DEC);
Serial.print ("Y: ");
Serial.print (joy_y_axis, DEC);
Serial.print ("AccX: ");
Serial.print (accel_x_axis, DEC);
Serial.print ("AccY: ");
Serial.print (accel_y_axis, DEC);
Serial.print ("AccZ: ");
Serial.print (accel_z_axis, DEC);
Serial.print (z_button, DEC);
Serial.print (" ");
Serial.print (c_button, DEC);
Serial.print ("\r\n");
i++;
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
void muovi ( uint8_t x, uint8_t y){
float tilt = (700 - x*2*2);
float tilt2 = (0x7E - y + 0x7E) *2*2;
tilt = (tilt);
pulseWidth = (tilt * 5) + minPulse;
tilt2 = (tilt2-288);
pulseWidth2 = (tilt2 * 5) + minPulse2;
pwbuff[pwbuffpos] = pulseWidth;
pwbuff2[pwbuffpos2] = pulseWidth2;
if( ++pwbuffpos == pwbuffsize ) pwbuffpos = 0;
if( ++pwbuffpos2 == pwbuffsize ) pwbuffpos2 = 0;
pulseWidth=0;
pulseWidth2=0;
for( int p=0; p pulseWidth += pwbuff[p];
pulseWidth2 += pwbuff2[p];
pulseWidth /= pwbuffsize;
pulseWidth2 /= pwbuffsize;
Visit Our Store »
Go Pro Today »
#include
#include
#include
uint8_t outbuf[6];
int cnt = 0;
int ledPin = 13;
int servoPin = 7;
int servoPin2 = 6;
int pulseWidth = 0;
long lastPulse = 0;
int z_button = 0;
int c_button = 0;
int refreshTime = 20;
int minPulse = 1000;
int minPulse2 = 500;
int dtime=10;
long pwbuffpos = 0;
void setup()
Serial.begin (19200);
Wire.begin ();
nunchuck_init ();
Wire.send (0x40);
Wire.send (0x00);
void send_zero()
Wire.send (0x00);
int t = 0;
void loop()
t++;
if( t == 1) {
t = 0;
cnt++;
if (cnt >= 5) {
// printNunchuckData();
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
switch (c_button) {
case 1:
switch (z_button) {
case 0:
break;
case 1:
muovi();
break;
break;
case 0:
switch (z_button) {
case 0:
delay(10000);
break;
case 1:
delay(3000);
break;
break;
cnt = 0;
send_zero();
} // if(t==)
updateServo();
delay(dtime);
void updateServo() {
int i=0;
int accel_x_axis = outbuf[2]; // * 2 * 2;
int accel_y_axis = outbuf[3]; // * 2 * 2;
int accel_z_axis = outbuf[4]; // * 2 * 2;
int z_button = 0;
int c_button = 0;
z_button = 1;
c_button = 1;
accel_x_axis += 2;
accel_x_axis += 1;
accel_y_axis += 2;
accel_y_axis += 1;
accel_z_axis += 2;
accel_z_axis += 1;
Serial.print (" ");
i++;
return x;
void muovi (){
float tilt = (700 - outbuf[3]*2*2);
float tilt2 = outbuf[2]*2*2;
tilt = (tilt);
pulseWidth=0;
pulseWidth2=0;
sketch_feb14a.cpp:3:13: error: #include expects "FILENAME" or
sketch_feb14a.cpp:4:13: error: #include expects "FILENAME" or
sketch_feb14a.cpp:5:14: error: #include expects "FILENAME" or
sketch_feb14a.cpp:6:47: error: #include expects "FILENAME" or
sketch_feb14a:7: error: 'Servo' does not name a type
sketch_feb14a.cpp: In function 'void setup()':
sketch_feb14a:45: error: 'myservo' was not declared in this scope
sketch_feb14a:48: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void nunchuck_init()':
sketch_feb14a:61: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void send_zero()':
sketch_feb14a:69: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void loop()':
sketch_feb14a:86: error: 'Wire' was not declared in this scope
sketch_feb14a:119: error: 'myservo' was not declared in this scope
sketch_feb14a:124: error: 'myservo' was not declared in this scope
sketch_feb14a.cpp: In function 'void muovi(uint8_t, uint8_t)':
sketch_feb14a:250: error: expected `;' before 'pulseWidth'
sketch_feb14a:250: error: expected `)' before ';' token
sketch_feb14a:251: error: name lookup of 'p' changed for new ISO 'for' scoping
sketch_feb14a:250: error: using obsolete binding at 'p'
sketch_feb14a.cpp: At global scope:
sketch_feb14a:254: error: expected constructor, destructor, or type conversion before '/=' token
sketch_feb14a:255: error: expected constructor, destructor, or type conversion before '/=' token
sketch_feb14a:257: error: expected declaration before '}' token
1. try using version 23 for the Arduino Software.
2. Tell the author of this tutorial to try and fix the code.
