3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino / Wii controlled Lego Star Wars rocket turret
Step 3Arduino Sketch
// Based on code from http://www.ideavirus.it/ adapted with help from Oliver at London Hackspace. Includes are: wire.h, string.h, stdio.h and Servo.h - for some reason Instructables drops them when I paste my code.
 #include
 #include
 #include
 #include   // controls the trigger servo only
 Servo myservo;  // create servo object to control trigger servo
int pos = 90;    // variable to store the trigger servo position
 uint8_t outbuf[6];
 int cnt = 0;
 int ledPin = 13;
 int servoPin = 7;
 int servoPin2 = 6;
 int pulseWidth = 0;
int pulseWidth2 = 0;
 long lastPulse = 0;
 long lastPulse2 = 0;
 int z_button = 0;
 int c_button = 0;
 int refreshTime = 70;  //tweaked for FutabaS3003 servos
 int minPulse = 600;  //tweaked for FutabaS3003 servos
 int minPulse2 = 600;  //tweaked for FutabaS3003 servos
 int maxPulse     =  2400; // maximum servo position
 int maxPuls2e     =  2400; // maximum servo position
 int dtime=10;
 #define pwbuffsize 10
 long pwbuff[pwbuffsize];
 long pwbuffpos = 0;
 long pwbuff2[pwbuffsize];
 long pwbuffpos2 = 0;
 void setup()
    myservo.attach(8);  // attaches the trigger servo on pin 8 to the servo object
     Serial.begin (9600);
     Wire.begin ();
     nunchuck_init ();
     pinMode(servoPin, OUTPUT);
     pinMode(servoPin2, OUTPUT);
     pulseWidth = minPulse;
    pulseWidth2 = minPulse2;
     Serial.print ("Finished setup\n");
 void nunchuck_init()
     Wire.beginTransmission (0x52);
     Wire.send (0x40);
     Wire.send (0x00);
     Wire.endTransmission ();
 void send_zero()
     Wire.send (0x00);
 int t = 0;
 void loop()
     t++;
     long last = millis();
     if( t == 1) {
         t = 0;
         Wire.requestFrom (0x52, 6);
         while (Wire.available ()) {
             outbuf[cnt] = nunchuk_decode_byte (Wire.receive ());
             digitalWrite (ledPin, HIGH);
             cnt++;
         if (cnt >= 5) {
             int z_button = 0;
             int c_button = 0;
             if ((outbuf[5] >> 0) & 1)
                 z_button = 1;
             if ((outbuf[5] >> 1) & 1)
                 c_button = 1;
             switch (c_button) {
             case 1:
             muovi( outbuf[3] ,outbuf[2] );
                 break;
             case 0:
             muovi( outbuf[1]/2+0x3E ,outbuf[0]/2+0x3E );
                 break;
            switch (z_button) {
                case 0:
     for(pos = 90; pos >= 120; pos += 1)  // fires trigger when Z button pressed
    myservo.write(pos);
    delay(15);
  for(pos = 120; pos >= 90; pos -= 2)     // returns trigger to center
    myservo.write(pos);
    delay(15);
                    break;
                 case 1:
                     break;
         cnt = 0;
         send_zero();
     updateServo();
     delay(dtime);
 void updateServo()
     if (millis() - lastPulse >= refreshTime) {
         digitalWrite(servoPin, HIGH);
         delayMicroseconds(pulseWidth);
         digitalWrite(servoPin, LOW);
         digitalWrite(servoPin2, HIGH);
         delayMicroseconds(pulseWidth2);
         digitalWrite(servoPin2, LOW);
         lastPulse = millis();
 int i=0;
 void printNunchuckData()
     int joy_x_axis = outbuf[0];
     int joy_y_axis = outbuf[1];
     int accel_x_axis = outbuf[2];
     int accel_y_axis = outbuf[3];
     int accel_z_axis = outbuf[4];
     int z_button = 0;
     int c_button = 0;
         z_button = 1;
         c_button = 1;
     if ((outbuf[5] >> 2) & 1)
         accel_x_axis += 2;
     if ((outbuf[5] >> 3) & 1)
         accel_x_axis += 1;
     if ((outbuf[5] >> 4) & 1)
         accel_y_axis += 2;
     if ((outbuf[5] >> 5) & 1)
         accel_y_axis += 1;
     if ((outbuf[5] >> 6) & 1)
         accel_z_axis += 2;
     if ((outbuf[5] >> 7) & 1)
         accel_z_axis += 1;
     Serial.print (i,DEC);
     Serial.print ("\t");
     Serial.print ("X: ");
     Serial.print (joy_x_axis, DEC);
     Serial.print ("Y: ");
     Serial.print (joy_y_axis, DEC);
     Serial.print ("AccX: ");
     Serial.print (accel_x_axis, DEC);
     Serial.print ("AccY: ");
     Serial.print (accel_y_axis, DEC);
     Serial.print ("AccZ: ");
     Serial.print (accel_z_axis, DEC);
     Serial.print (z_button, DEC);
     Serial.print (" ");
     Serial.print (c_button, DEC);
     Serial.print ("\r\n");
     i++;
 char nunchuk_decode_byte (char x)
     x = (x ^ 0x17) + 0x17;
     return x;
 void muovi ( uint8_t x, uint8_t y){
     float tilt = (700 - x*2*2);
     float tilt2 = (0x7E - y + 0x7E) *2*2;
     tilt = (tilt);
     pulseWidth = (tilt * 5) + minPulse;
     tilt2 = (tilt2-288);
     pulseWidth2 = (tilt2 * 5) + minPulse2;
     pwbuff[pwbuffpos] = pulseWidth;
     pwbuff2[pwbuffpos2] = pulseWidth2;
     if( ++pwbuffpos == pwbuffsize ) pwbuffpos = 0;
     if( ++pwbuffpos2 == pwbuffsize ) pwbuffpos2 = 0;
     pulseWidth=0;
     pulseWidth2=0;
     for( int p=0; p          pulseWidth += pwbuff[p];
         pulseWidth2 += pwbuff2[p];
     pulseWidth /= pwbuffsize;
     pulseWidth2 /= pwbuffsize;
2 comments
Feb 14, 2011. 9:40 AMDannne11 says:
im getting error
sketch_feb14a.cpp:3:13: error: #include expects "FILENAME" or
sketch_feb14a.cpp:4:13: error: #include expects "FILENAME" or
sketch_feb14a.cpp:5:14: error: #include expects "FILENAME" or
sketch_feb14a.cpp:6:47: error: #include expects "FILENAME" or
sketch_feb14a:7: error: 'Servo' does not name a type
sketch_feb14a.cpp: In function 'void setup()':
sketch_feb14a:45: error: 'myservo' was not declared in this scope
sketch_feb14a:48: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void nunchuck_init()':
sketch_feb14a:61: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void send_zero()':
sketch_feb14a:69: error: 'Wire' was not declared in this scope
sketch_feb14a.cpp: In function 'void loop()':
sketch_feb14a:86: error: 'Wire' was not declared in this scope
sketch_feb14a:119: error: 'myservo' was not declared in this scope
sketch_feb14a:124: error: 'myservo' was not declared in this scope
sketch_feb14a.cpp: In function 'void muovi(uint8_t, uint8_t)':
sketch_feb14a:250: error: expected `;' before 'pulseWidth'
sketch_feb14a:250: error: expected `)' before ';' token
sketch_feb14a:251: error: name lookup of 'p' changed for new ISO 'for' scoping
sketch_feb14a:250: error: using obsolete binding at 'p'
sketch_feb14a.cpp: At global scope:
sketch_feb14a:254: error: expected constructor, destructor, or type conversion before '/=' token
sketch_feb14a:255: error: expected constructor, destructor, or type conversion before '/=' token
sketch_feb14a:257: error: expected declaration before '}' token
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Jonathan Robson
Science museum exhibit design and fabrication manager, stagehand, ballet shoe maker, theatre production manager, project manager and art director of the Beijing Aquarium rainforest exhibit, film extra...
more »
