Arduino Wireless GSM Security System
16,458
54
Posted
Introduction: Arduino Wireless GSM Security System
Hi, here i will show you my gsm security system i made, you should have some experience with electronics beforehand. Feel free to modify this project in any way you like. All parts are bought from DX.com.
The reason its wireles is so you dont have everything right behind the door, so for security reasons, there is about 10m from sensor to gsm module.
It takes about 5 seconds, from door is opened, til i get a call.
What you will need:
Parts:
x2 Arduino (i use uno)
x1 GSM/GPRS Shield (with SIM900 chip, most common)
x1 Unlocked SIM card without PIN
x1 Reed switch or reed module
x1 433mhz RF transmitter
x1 433mhz RF receiver
x1 Strong magnet (i use neodymium)
+ A lot of wire
Optional:
Enclosure
Tape
Different sensor (PIR etc)
Libraries:
Virtual Wire
SoftwareSerial
You can solder a wire to ANT on rf module like i have done to get better range
Step 1: Building the Transmitting Circuit
Now you will connect your transmitting rf module and reed switch to arduino number 1
TX module:
DATA > digital pin 10
VCC > 3.3v
GND > Ground
Reed module:
DO > digital pin 12
VCC > 5v
Ground > Ground
Step 2: Building the Receiving Circuit
Now, place your gsm module on the second arduino
Depending on your GSM module,
you will connect the RX module:
DATA > digital 9
VCC > 5v
Ground > Ground
I have included a picture of how to connect RX using the gsm module i have.
Links to products used:
GSM Shield
Reed Switch
433mhz RF modules
Note: The GSM shield requires power from a wall outlet
Step 3: Code
The gsm shield powers up when you power the arduino
I have included a 20 sec delay, so you have time to get out the door
And a delay so it waits 30 sec between calls
Transmitting code
Receiving code
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
Transmitting code and receiving code not fount ?
arm7 interfacing lcd and gsm with source code
http://s4silver.blogspot.in/p/blog-page_74.html
