Arduino YL-44 Buzzer Module
25,121
10
11
Posted in TechnologyArduino
Introduction: Arduino YL-44 Buzzer Module
About: Hello, My name is Samuel, I am a student. I love micro controllers like arduino, they are my favorite interest. I also do geocaching, a worldwide treasure hunt game. I hope you enjoy my instructables! Samuel
Welcome to this tutorial!
So about a time ago I sat and looked around at my favorite site for ordering all kinds of arduino sensors, boards and much more. You might already have guessed it, but I am of course speaking about www.aliexpress.com. I just was looking and an actuator got my eyes. It was a buzzer module which was great for a future project. You can for example make it buzz every time you start your program. Although once I got it home, I was not really prepared for how to deal with this new unit. This might sound kind of stupid, but I am just a newbie to arduino. Got my genuine ardunio UNO for about a month or two ago, so bare with me.
After searching google, contacting seller and searched on google again, I did not find a solution. Then finally the seller provided me with what I needed, a square wave.
Now, I am going to show you how to connect this module and speak with it, sorry, make it understand my crappy code.
Step 1: Parts
Start by getting the required parts:
YL-44 buzzer (1$)
Any arduino board really (3-15$ depending on which one you get)
A couple of jumper wires (2-3$)
Step 2: Connections
Notice that I am using the arduino MEGA, but you can use any board you would like, for example, this code works on both the UNO and the Nano.
Your connections should be like the pictures and as following:
VCC -> Arduino 5V
I/O -> Any arduino PWM pin (I used 3)
GND -> Arduino GND
Step 3: Your Code
Now your code is easy as ABC, although we will create our own fast function to interact more easily.
This code worked great for me without any errors, enjoy!
Refer to Comments for explanation
//Code written by Samuel.
int buzzerPin = 3; //Define buzzerPin
void setup() { pinMode(buzzerPin, OUTPUT); //Set buzzerPin as output beep(50); //Beep beep(50); //Beep delay(1000); //Add a little delay
void loop() { beep(50); //Beep every 500 milliseconds delay(500); }
void beep(unsigned char delayms) { //creating function analogWrite(buzzerPin, 20); //Setting pin to high delay(delayms); //Delaying analogWrite(buzzerPin ,0); //Setting pin to LOW delay(delayms); //Delaying }
Step 4: Finished
Now I hope this helped you, and that your YL-44 is working now. Thanks for reading and as always, please favorite and subscribe for more tutorials.
Samuel
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    11 Comments
    If you have a unit that need digital input to work (as my YL-44). You could try this code for some fun:
    /* Buzzer type YL-44 with VCC, GND and I/O pin
    * YL-44 will have sound ON when I/O is LOW
    * Written by Kjartan, LA6SRA, 2015
    int buzzPin= 12; // I/O-pin from buzzer connects here
    const int wpm = 20; // Morse speed in WPM
    const int dotL = 1200/wpm; // Calculated dot-length
    const int dashL = 3*dotL; // Dash = 3 x dot
    const int sPause = dotL; // Symbol pause = 1 dot
    const int lPause = dashL; // Letter pause = 3 dots
    const int wPause = 7*dotL; // Word pause = 7 dots
    void setup()
    pinMode(buzzPin,OUTPUT); // Set buzzer-pin as output
    void loop()
    dash();
    dot();
    dash();
    dot();
    delay(lPause-sPause); // Subtracts pause already taken
    dash();
    dash();
    dot();
    dash();
    delay(wPause-sPause); // Subtracts pause already taken
    void dot(){
    digitalWrite(buzzPin, LOW); // Tone ON
    delay(dotL); // Tone length
    digitalWrite(buzzPin, HIGH); // Tone OFF
    delay(sPause); // Symbol pause
    return;
    void dash(){
    delay(dashL); // Tone length
    return;
    Thank you so much! Had really bad problems with constant buzzing until found your code. Now my buzzer starts to morse "Fridge Open" if someone leaves the door open :p.
    I tried it, but it doesnt make any sound :( , I have same problem with constant buzzing, code I copy/paste from KjartanA's comment and connected like this:
    And Im using Wemos D1, does anybody know what Im doing wrong? :(
    Well I made mistake with wrong pinMode, but it still constantly buzzing WHY? :(
    My Friends !! We leave the YL-44 Buzzer in HIGH mode and not LOW, and it does not bother or get warm.
    digitalWrite (buzzPin, HIGH);
    I'm looking for a buzzer than can be turned on when the control signal is high...
    On ebay I found a buzzer that says 'High Level Trigger for Arduino', I assume this to mean when the control signal is HIGH, the buzzer will sound, right?
    However, if it has a pnp (2TY) transistor shouldn't the base control signal be LOW for the buzzer to sound? Only if it had an npn (ex. 2N2222) transistor THEN the base control signal is HIGH for the buzzer to sound.
    Also is it possible for the VCC and the control signal to be 12V instead of 5V? Or would the buzzer and/or limiting current resistor have to change?
    I did the same configuration.
    Get a very loud noise and a beep at the frequence you indicate.
    Do you know why I am getting the noise ?
    YL-44 is not intended to be used with a PWM-pin. Instead you set the I/O-pin LOW to get the buzzer going. And HIGH to make it stop buzzing. If you use PWM there will be a constant buzzing from the unit and just small changes when the PWM changes.
    There may be different types of the unit out there. At least this tutorial would indicate that.
    +1
    My 3 PIN buzzer does not work in PWM mode, works only as KjartanA says.
