- unencrypt the barcode in software on the arduino
- i didn't want to cut into the Cuecat in case I broke it, not hard to replace, but that's not the point ;-)
- get it to write only the bar code to the serial port, and I can use some terminal emulator (TeraTerm,Putty or SecureCRT) to write the data to a file as I furiously scan like a boss all items with a barcode in the house.
Step 1: Connecting the CueCat to Arduino
There is no continuous path between the 2 ports (Except Power and GND) as a multimeter and continuity test confirmed. So using the female port as a way to access the cuecat signal did not work.
PS2 female connectors are hard to find these days, so I cut the female connector from the cuecat and used that to break out the wires...
The Cue cat cable has 6 wires, marked on the board as 1-6
1. Brown (+5V)
2. Red (DATA Female connector)
3. Black (Clock Female Connector)
4. Orange (DATA Male connector)
5. Yellow (Clock Male Connector)
6. Black - Cable is thicker than other black (Ground)
When cut, the female adapter, has the following which will map to the connector inside the Cuecat as follows
1. Brown (+5V)
2. Red (DATA Female connector) to Orange(pin4)
3. Black (Clock Female Connector) to Yellow (pin5)
4. Bare wire (GND)
I tinned the wires with flux and solder to make them a little more durable, and wired them to a terminal shield on the Arduino.
Step 2: Getting the first code
http://www.arduino.cc/playground/Main/PS2Keyboard
The only thing to watch out for is;
- The CLK is used as interrupt, and so ensure you connect to a pin that supports interrupts
e.g. on the Mega 2560 http://arduino.cc/en/Main/ArduinoBoardMega2560
External Interrupts: 2 (interrupt 0), 3 (interrupt 1), 18 (interrupt 5), 19 (interrupt 4), 20 (interrupt 3), and 21 (interrupt 2).
I used Pin 3... Which is a bit annoying as now all the pins are not on same side of the board :-( (first world problems)
And a few swipes, check all wires are connected right and ...
.C3nZC3nZC3nYCNP1Chz6CNnY.bNjW.D3T6C3nZE3jZD3bZDa.
TIP: Look at ASCII codes, NOT printable characters...
You can see I played with the code a little, as when looking at output there are always non printable characters, so I wrote the code to show the ASCII code.
Useful: http://en.wikipedia.org/wiki/ASCII
OUTPUT ASCII value -> printed Character
International Keyboard Test:
46->.
67->C
51->3
110->n
89->Y
[deleted for brevity...]
88->X
69->E
87->W
46->.
13->
Note that there does not seem to be anything strange at the start, but the end is /13 which is a Carriage return, ie, end of the code
I did expect to see ALT-F10 being sent as on my linux box it kept minimising and expanding the window on each scan, and that is the keystroke that does that... if the Arduino doesn't see it, then I am OK with that...
Step 3: Decoding the barcode
.<SERIAL>.<CODE>.<BARCODE>.
<SERIAL> is the unique serial number that each cuecat has. The idea being that the company distributing them can track what you scan. I don't see a need for this, so will ignore it.
<CODE> is the BarCode type. I dont have an exhaustive list but I have seen "E13", "IB5" etc. I would think this may help decide where to look up the bar code, as I imagine that there are many sources of barcode data. I imagine that books, food products and teh barcodes you print may be in different formats. I know that some barcodes are numbers only, some are a mix of letters and numbers
<BARCODE> the interesting bit :-)
OK so how to decode...
I trolled the internet and found lots of example code in various (non processing/arduino) format with little explanation. So I grabbed a reliable version that worked well on my Linux Box that was written in PERL.
Here is the amazingly terse PERL script by Larry Wall
http://www.accipiter.org/download/decue.txt
To describe it, and understand it, I did it in excel as follows... the file is attached to play with.
1) Break the code and break into the 2 pieces described above, and decrypt one at a time as described
2) Each set of 4 characters is "unencrypted" into 3. So the length of the final output is 3/4 of the input string, Round down if necessary. (encryption going the other way clearly needs to pad out characters to ensure no information is lost)
3) Take the 4 characters and map to ASCII
- effectively "a-zA-Z0-9+-" maps to ASCII characters 32-96 (ie SPACE ' ' to '_')
- so E, N, b, X map to >, G, !, X respectively
I found it a problem to keep converting back and forth between ASCII characters and Codes (E.g. E<-> 69) as some non printable characters were hard to troubleshoot and working out which non printable character was being printed is tough. So in the final code I worked exclusively in ASCII codes until the last step. IE the yellow lines were useful while reverse engineering this, but are not part of the final code...
4) Subtract 32 from the ASCII code
- >, G, !, X has teh ASCII code of 62,71,33,81
- Subtracting 32 gives us 30,39,1,49
5) Treat the above characters and ASCII codes as 6 bit numbers (4 x 6 = 24 bits)
- 30 gives us 01110, so
- 30,39,1,49 gives us 0 1 1 1 1 0 1 0 0 1 1 1 0 0 0 0 0 1 1 1 0 0 0 1
6) Treat the binary string as a string of 8 bit characters, this is how it becomes 3/4 of the size! (3 x 8 = 24 bits)
- 0 1 1 1 1 0 1 0 0 1 1 1 0 0 0 0 0 1 1 1 0 0 0 1
- 122, 112,113 which is z,p,q in ASCII format
7) Take each of the 3 codes and Exclusive OR it with 67 = 01000011
- 122 XOR 67 = 57
122 = 01111010
67 = 01000011
00111001 = 57
- 122, 112,113 becomes 57,51,50
8) Convert to ASCII
- 57,51,50 becomes 932, which is the first 3 digits of my barcode!!!!
9) repeat for each 4 digits until you get a '.' :-)
cuecat_decode.zip22 bytesStep 4: Putting it all together
I made the format CSV style so I can cut and paste into EXCEL or upload easily...
I tried to make it into a library, but it is buggy and I ran out of time :-(
I will add the library later if I get it done...
Step 5: Last points
If you try it and it works, let me know.
cueCatV12.zip3 KB
Visit Our Store »
Go Pro Today »
There's a wide variety of mods to the CueCat - declawing it (disabling the unit's individual serial number) and neutering it (eliminating the serial number all together and the encoding scheme). The first amazing part about neutering a CueCat is once it's done the CueCat becomes a plaintext general purpose bar code reader which simulates a keyboard without any drivers needed. Just plug it in and any scanned barcodes are automatically "typed". The more amazing part is the mod to neuter a cat is trivial - soldering in a single wire to the appropriate already existing pass through hole on the circuit board! The entire process takes about 10 minutes and can be done by anybody with novice soldering skills, in fact some folks do it without _any_ electronics skills, just reusing a bread twist-tie as a wire and squeezing the wire into the appropriate location.
The mod is actually less invasive than what you've done to attach the PS/2 cable to the Arduino.
One caution is there are many revisions to the circuit, fortunately documented in the circuit board's silkscreen. Here's one website with info on how to do the mod on all of the known revisions to the circuit board.
This model was k023a016 REV:C, I don't know how many others not documented on that original site there were.
In this case, it was like climbing the mountain. It was there :-)
And I don't have PS2 port on my laptop :-)
The PS2 to USB adapter works fine with the CueCat.
It would be nice to get an all software fix working, because then my project could be more versatile.
