Introduction: Arduino Controlled L293D Robot ( Part 1 - Update 1.0 )
Picture of Arduino Controlled L293D Robot ( Part 1 - Update 1.0 )
Here is part 1 of the Arduino and L293D Robot.This is part of a series of instructables leading to a Line follower Robot.
This is a basic Robot made by controlling two motors via the L293D chip through an Arduino Board.
I have done this project in the past with similar set up just not with an Arduino Board.
Do let me know what you think of this project and if I made any mistakes.
Step 1: Parts
Arduino Board
Breadboard
L293D Chip
Two Motors
9 Volt Battery
6 Volt Battery Pack
Step 2: Wiring the L293D Chip
Picture of Wiring the L293D Chip
Pin 4 ,Pin 5,Pin 12 and Pin 13 from L293D Chip Connect to Ground (Negative On Breadboard)
Pin 1,Pin 9 and Pin 16 from L293D Chip Connect to 5 Volts (Positive On Breadboard)
Pin 8 from L293D Chip Connects to 6 Volts (Positive Lead of Battery Pack)
Pin 3 from L293D Chip Connects to Right Motor
Pin 6 from L293D Chip Connects to Right Motor
Pin 11 from L293D Chip Connects to Left Motor
Pin 14 from L293D Chip Connects to Left Motor
Output pins on Arduino to control Right Motor :
Pin 2 from L293D Chip Connects to Output Pin on Arduino
Pin 7 from L293D Chip Connects to Output Pin on Arduino
Output pins on Arduino to control Left Motor :
Pin 10 from L293D Chip Connects to Output Pin on Arduino
Pin 15 from L293D Chip Connects to Output Pin on Arduino
Step 3:
Step 4: Connecting the Motors to L293D Chip
Picture of Connecting the Motors to L293D Chip
Step 5: Connecting the Pins to 5 Volts and Ground
Picture of Connecting the Pins to 5 Volts and Ground
Pin 8 from L293D Chip Connects to 6 Volts (Positive On Breadboard)
Step 6: Output Pins on Arduino to Control the Motors
Picture of Output Pins on Arduino to Control the Motors
Step 7: Power
Picture of Power
9 Volts powering the Arduino Board
6 Volts(4 Double A 1.5 Volts batteries) connected to the Breadboard powering the motors.
Step 8: Basic Code to Go Straight
// The following is the basic Arduino code which runs a loop that makes the Robot go straight forward.
int LeftMotorForward = 10; // Pin 10 has Left Motor connected on Arduino boards.
int LeftMotorReverse = 9; // Pin 9 has Left Motor connected on Arduino boards.
int RightMotorForward = 12; // Pin 12 has Right Motor connected on Arduino boards.
int RightMotorReverse = 13; // Pin 13 has Right Motor connected on Arduino boards.
void setup()
  pinMode(LeftMotorForward, OUTPUT);  // initialize the  pin as an output.
  pinMode(RightMotorForward, OUTPUT);  // initialize the  pin as an output.
  pinMode(LeftMotorReverse, OUTPUT);  // initialize the  pin as an output.
  pinMode(RightMotorReverse, OUTPUT);  // initialize the  pin as an output.
// The following Loop is to make the Robot go staright
void loop()
   digitalWrite(RightMotorForward, HIGH);   // turn the Right Motor ON
   digitalWrite(LeftMotorForward, HIGH);   // turn the Left Motor ON
   delay(10000);               // wait for  10 seconds
   digitalWrite(RightMotorForward,LOW);   // turn the Right Motor OFF
   digitalWrite(LeftMotorForward, LOW);   // turn the Left Motor OFF
Step 9: Basic Code to Go Right
void setup()
// The following Loop is to make the Robot go Right
void loop()
   digitalWrite(RightMotorForward, LOW);   // turn the Right Motor OFF
Step 10: Basic Code to Go Left
void setup()
// The following Loop is to make the Robot go Left
void loop()
Step 11: Basic Code to Reverse
void setup()
// The following Loop is to make the Robot Reverse
void loop()
   digitalWrite(RightMotorReverse, HIGH);   // turn the Right Motor ON
   digitalWrite(LeftMotorReverse, HIGH);   // turn the Left Motor ON
Step 12: Code to Make Robot Go Forward,Right,Left,Reverse and Stop All in a Loop
void setup()
void loop()
   void Driveforward();
   void Rightturn();
   void Leftturn();
   void Reverse();
   delay(10000);               // wait for a 10 seconds
   digitalWrite(RightMotorReverse, LOW);   // turn the Right Motor ON
   digitalWrite(LeftMotorReverse, LOW);   // turn the Left Motor ON
   void Allstop();
NIkheel94 (author)2015-05-12
My apologies if i haven't been answering any Question.
I have been really busy with school and haven't had a chance to get back to instructables. During the next few weeks and summer months i will try to answer all questions and help with any issues you may have. I will also Update this instructables and make a better and more detailed version.
Thank you for your patience, Feedback and support.
I greatly appreciate it
Once again i am sorry if i wasnt able to help you.
MSFrdsR (author)NIkheel942017-02-05
can help me ?
MSFrdsR made it! (author)2017-02-05
can you make toturial using this ? make toturial how to set up it for controlled robot
Bayu AdrianA (author)2017-01-30
hello i have problem the code "int LeftMotorForward = 10;" error so I copy to code the up why erorr please help me
rrawat2 (author)2014-09-01
int IN1=13;
int IN2=12;
int IN3=11;
int IN4=10;
void setup()
pinMode(IN1,OUTPUT);
digitalWrite(IN1,LOW);
pinMode(IN2,OUTPUT);
digitalWrite(IN2,LOW);
pinMode(IN3,OUTPUT);
digitalWrite(IN3,LOW);
pinMode(IN4,OUTPUT);
digitalWrite(IN4,LOW);
Serial.begin(9600);
void loop()
if(Serial.available()>0)
char letter=Serial.read();
if(letter=='8') //forward moving robot
digitalWrite(IN1,HIGH);
digitalWrite(IN3,HIGH);
Serial.println("THE ROBOT WILL MOVE FORWARD");
else if(letter=='5') //STOP ROBOT
Serial.println("THE ROBOT WILL BE STOP");
else if(letter=='2') //REVERSE ROBOT
digitalWrite(IN2,HIGH);
digitalWrite(IN4,HIGH);
Serial.println("THE ROBOT WILL MOVE REVERSE");
else if(letter=='4') //LEFT ROBOT
Serial.println("THE ROBOT WILL MOVE LEFT");
else if(letter=='6') //RIGHT MOVING ROBOT
Serial.println("THE ROBOT WILL MOVE RIGHT");
//this is move on by keyboard button so try and enjoy
shivamt7 (author)rrawat22016-01-30
hey why you'v given datatype as char letter and value as int. and what does letter signify.
navneet kaur (author)2015-03-22
can we incorporate IR sensor in this project, if yes then what changes are required?
NIkheel94 (author)navneet kaur2015-05-12
Here is Part 2 where i did add IR to the Project
https://www.instructables.com/id/Arduino-and-L293D-Robot-Part-2-Infrared-Sensor/
shivamt7 (author)NIkheel942016-01-30
hey can we move in all 4 directions i.e including backwards
You wouldn't have to make any physical changes, only to the code.
Just add the IR sensor to the Arduino and connect it to the Digital pins if i am not mistaken.
I have been really busy with school. If you are not in a rush i can make a complete version with IR and get back to you in the next few weeks.
robbinscientist (author)2015-11-05
hi sir i want to make this without a bread board
Pruthi (author)2015-10-12
I'm using an 11v battery for this will i need to use a diode and transistor to control the voltage being carried to the arduino?
techno man (author)2015-06-27
Amaizing ......
One of the easiest,low cost and simplest arduino robot project in the web
Thank you sir for this awesome project
Waiting for more projects like this
Harrylorence (author)2015-06-21
Cool man your explanation is simple and great..do more instructables..waiting for thae next one..
faizi.barcaboy (author)2015-01-28
Thanks Alot! It Works I am so Happy (Y)
NIkheel94 (author)faizi.barcaboy2015-05-26
I am happy that i was able to make you happy.
yhdesai (author)2015-02-01
MAKE A SHIELD OF L293D MOTOR CONTROLLER
NIkheel94 (author)yhdesai2015-05-26
Is that a Suggestion or a Request ?
I'll probably design a schematic one day and make my own at home.
Ramasubramanian Aditya (author)2015-02-01
Thank You Very Much! You explained the concept very clearly in comparison to other instructables, and it worked!!!!!
Thank you. I am glad it worked for you.
ICareP (author)2015-05-11
great work, i hope it works. Can you pls post a schematics image using fritzing
NIkheel94 (author)ICareP2015-05-12
I never head of fritzing before and unfortunately i have been really busy with school and life.
I will try my best to make a detailed schematic using fritzing as soon as possible.
Thank you for your patience.
ICareP (author)NIkheel942015-05-13
yh, fritzing is open-source and free http://fritzing.org/download/ and it allows you to draw schematics and creates pcb layouts form those schematics. I'm also busy w/ school and life, I couldn't see clearly the images posted, I'm building a robot etoy prototype for anyone we're on kickstarter already you can spread the word, or back us to http://kck.st/1D7lOtk cheers
rudy.hengeveld (author)2014-12-21
thanks a lot..it works...Mars here we come
maljundi (author)2014-12-06
hi.. i want to get l293d ic but i think it's need (heat sink) !!
so plz.. explain y u didn't use heat sink and really it's need it ??!
sai instruct (author)2014-10-23
wat happens wen 9V is given to enable pins
input 1 of l293d ic will connect on arduino13 pin.
input 2 of l293d ic will connect on arduino12 pin.
input 3 of l293d ic will connect on arduino10 pin.
input 4 of l293d ic will connect on arduino 9 pin.
and make the circuit by using this circuit diagram and code will available below.(rrawat2)
tisaconundrum (author)2014-04-09
So I figured out how to get it wired correctly. All the batteries need to be grounded together.
Edit: I had the batteries connected to the wrong pins. I was testing and the motor wasn't even running. So here is the correct schemtaic
Now where does the ground for the 5 V battery go?
asarkar9 (author)2014-03-12
Do we have to convert a program written in C++ to machine language, in order to make ARDUINO UNO work? If yes, then how to do it? And can you please give a link for downloading the software required for ARDUINO? Please reply ASAP.... it's very important. Thanks.
skant1 (author)asarkar92014-04-05
NO WE DON'T HAVE TO CONVERT THE CODE TO ASSEMBLY(IT IS ACTUALLY AN ADVANTAGE WITH ARDUINO).....PROGRAMMING ARDUINO IS VERY VERY SIMPLE...GO TO www.arduino.cc AND DOWNLOAD THE ARDUINO ZIP FOLDER
then open zip folder and save it to desktop and connect your arduino board to usb port using usb cable and open device manager and find your arduino in ports section and right click on it and click update driver and choose from pc then open arduino folder saved in desktop and choose drivers that is it....your arduino is connected and then do hardware as per above given and program the arduino using arduino application and upload it....you are done
paras11 (author)2014-02-27
hey i tried to follow d steps but my l293d gets really heated
can u tell me why is this happening???
:O
beginner13 (author)2013-12-11
wat r the output pins for arduino,where do i connect the pin2,pin7,pin10 and pin15 to arduino
Haitham khedr (author)2013-10-24
Hello, i am trying to drive a dc motor with L293D ,i supply 5 volts to pin 8 and when i measure the output voltage it is reduced to 2.6 volt when i connect the motor only,if the motor is not connected all the input is transfered to the output . Would you please help solving this problem?
Thanks
Hello, i am drive a dc motor with L293D ,i supply 5 volts to pin 8 and when i measure the output voltage it is reduced to 2.6 volt when i connect the motor only,if the motor is not connected all the input is transfered to the output . Would you please help solving this problem?
Thanks
Vee20 (author)2013-09-28
Hi there. Lovely instructable! Is there any way to slow down the speed of the motor? I find that it moves a bit too fast for my intended purpose. Thank you!
NIkheel94 (author)Vee202013-09-28
Try the following to see if it works,if it doesn't i will have to test it to figure it out.
Option 1 :
delay(10000); // waits for 10 seconds
This line will keep the motor on for 10 seconds.
delay(1000); // waits for a second
This line will keep the motor on for 1 second.
By adjusting the amounts of seconds you adjust the amount of time the motor stays on and this can be used to slow down turns.
Option 2 :
To slow down the motor try the following command.
The following is an Example for the Right Motor Only.
Follow the same structure for other motors you want to control.
Replace the command
with
analogWrite(RightMotorForward,N);
Let "N" be any number between 0 and 255, 0 is stop and 255 is the Highest speed.
Example: analogWrite(RightMotorForward,155);
This is a modification of the fade example from the Arduino Library.
Hope This Helps.
Vee20 (author)NIkheel942013-10-12
thank you. will try it out and get back to you :)
mgarg5 (author)2013-10-09
Does the motor need to have a feedback? I have a DC motor. Can i use it using this method.
Regards.
And i do hope you rspond fast . i need to et this done by this weekend :)
NIkheel94 (author)mgarg52013-10-09
No this project does not require Feed Back as it does not rely on sensory feedback to control movement. This project is based on predetermined preprogrammed commands. You can however edit the code to fit your needs.
Yes this Project can be done with a DC motor. A DC Motor can be controlled through the application of Voltage change and can be made to turn slower or faster.
Follow through the Steps and carefully read the instructions while using the images as aid and you should be fine.
cdragos george (author)2013-06-29
A wonderful guide to start working with Arduino Uno. As you can see I add a link in my article  where is an impressive collection of guides and tutorials to start working with Uno.
NIkheel94 (author)cdragos george2013-09-28
Thanks for including my project.
volt107 (author)2013-06-07
Thanks a lot for this tutorial man. This is probably the clearest and simplest arduino robot tutorial on the web! Got mine to work. Thanks again.
NIkheel94 (author)volt1072013-09-28
Glad you Liked it.
Thanks.
NIkheel94 (author)volt1072013-06-10
Thanks.
I think it could have been of better Quality but Thanks again.
ajimzack (author)2013-06-15
my project has been done...this is the link video..thanks,,http://www.youtube.com/watch?v=v2Y_s3R8EOY&feature=youtu.be
NIkheel94 (author)ajimzack2013-09-28
Looks Good.
Good Job.
volt107 (author)2013-06-05
Also, how are pins 1, 9, 16 connected to 5V? I just see them connected to negative on the breadboard.
About This Instructable
178,632views
82favorites
License:
More by NIkheel94:Streaming the Xbox 360 to Twitch using an older VGA/DVI PC Monitor with Seperate Sound (Monitor Without Speakers)Easy Basic Arduino Ethernet ControllerMost Basic Form of Hydroponics
Add instructable to:
