Introduction: Arduino and Visual Basic RF Over Temperature Humidity Measurement
We can see Arduino using 433 MHz RF with instantaneous display of temperature and humidity values as we do with the visual basic program.
http://make.robimek.com/arduino-visual-basic-wireless-temperature-humidity-control/
Let's start with temperature and humidity before our project then let us interface with the visual basic program. Materials:
  • 2 Number Arduino (no matter nano models will suffice.)
  • RF module 433 MHz (433 MHz, we used in this project. You can also use modules of different frequencies)
  • Temperature Humidity Meter Module
Step 1: Transmitter Circuit:
Picture of Transmitter Circuit:
Temperature and humidity values will be sent to the transmitter circuit and the receiver circuit.
Pin connector of the circuit:
Tx signal pin >> Arduino's digital 3.pin
Temperature-Humidity Sensor Data Pin >> Arduino's digital 2.Pin
Step 2: Receiver Circuit:
Picture of Receiver Circuit:
Our circuit will be transferred to the PC by taking the data receiver from the transmitter.
Circuit Connections:
Rx signal pin >> Arduino's digital 11.p
We have completed our transmitter and receiver circuits. Now let's start writing our interface with the visual basic program.
Step 3: Visual Basic Interface Program:
Picture of Visual Basic Interface Program:
You can design the form as shown in figure.
Tools Required to our form:
  • 3 Piece Button
  • 2 Number combobox
  • 2 Number Progressbar
  • 11 Number Label
  • 2 Number Picturebox
  • 1 Piece SerialPort
  • 1 Piece Timor
Step 4: Add the System Libraries.
Imports System
Imports System.ComponentModel
Imports System.Threading
Imports System.IO.Ports
Step 5: Let's Define Our Serial Port Object.
Dim myPort As Array ‘port name identification
Delegate Sub SetTextCallback(ByVal [text]As String)
Step 6: Let's Define Our Form Loader Part.
myPort = IO.Ports.SerialPort.GetPortNames()
ComboBox2.Items.Add(9600)
ComboBox2.Items.Add(19200)
ComboBox2.Items.Add(38400)
ComboBox2.Items.Add(57600)
ComboBox2.Items.Add(115200)
For i = 0 To UBound(myPort)
ComboBox1.Items.Add(myPort(i))
Next
ComboBox1.Text = ComboBox1.Items.Item(0)
ComboBox2.Text = ComboBox2.Items.Item(0
)Button2.Enabled = False
Step 7: Let's Define Our Butonu Necessary to Enable Us to Connect Our Ports to Receive Data.
Timer1.Start()SerialPort1.PortName = ComboBox1.Text
SerialPort1.BaudRate = ComboBox2.Text
SerialPort1.Parity = IO.Ports.Parity.None
SerialPort1.StopBits = IO.Ports.StopBits.One
SerialPort1.DataBits = 8SerialPort1.Open()
Label10.Text = “Connected sensors”
Button1.Enabled = FalseButton2.Enabled = True
TextBox4.ForeColor = Color.GreenLabel11.Text = “Receiving Data…”
Step 8: Let's Define Our Butonu Disconnect Necessary to Stop the Data Acquisition.
Timer1.Stop()SerialPort1.Close()
Button1.Enabled = TrueButton2.Enabled = FalseText
Box3.ForeColor = Color.Red
Label10.Text = “Disconnected.”
Label11.Text = “Data Stopped.”
Step 9: Let Us Define One of Our Combobox to Select the Port.
If SerialPort1.IsOpen = False Then
Else
MsgBox(“Port while you can not change”, vbCritical)End If
Step 10: Let Us Define for Us to Select the Required Baud Rate Value.
Else
End If
Step 11: Finally, the Serial Data Will Allow Us to Do Our Part Identification Is Necessary to Time.
Dim str As Stringstr = “1”
SerialPort1.Write(str)
Dim receiveddata As Integer = SerialPort1.ReadLine()
Label7.Text = receiveddata
If receiveddata < 0 Then
ProgressBar1.Value = -receiveddata
Else
ProgressBar1.Value = receiveddata
End If
System.Threading.Thread.Sleep(500)
Dim receiveddata2 As Integer = SerialPort1.ReadLine()
Label8.Text = receiveddata2
ProgressBar2.Value = receiveddata2
Step 12: Arduino Transmitter Software
#include <VirtualWire.h>
#include <dht11.h>
.#define DHT11PIN 2
dht11 DHT11;char msg[6];
void setup()
vw_setup(2400);
vw_set_tx_pin(3);
void loop()
int chk = DHT11.read(DHT11PIN);
int sicaklik =DHT11.temperature;
int nem = DHT11.humidity;
sprintf(msg, “%d,%d”, sicaklik, nem);
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); delay(1000);
Step 13: Arduino Receiver Software
int sicaklik;
int nem;
int i;
char x;
char StringReceived[6];
void setup(){ Serial.begin(115200);
vw_set_rx_pin(11); vw_setup(2400);
vw_rx_start();
void loop()
if(Serial.available()>0)
x=Serial.read();
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if(x==’1′)
if( vw_get_message(buf, &buflen) )
for (i = 0; i < buflen; i++)
StringReceived[i]= char(buf[i]);
sscanf(StringReceived, “%d,%d”,&sicaklik, &nem);
Serial.println(sicaklik);
delay(500);
Serial.println(nem);
delay(500);
memset( StringReceived, 0, sizeof( StringReceived));
Step 14: Description:
500 millisecond delay is happening with data acquisition software.
If the timer of the form System.Threading.Thread.Sleep(500) change this value should also change the value. Otherwise you will get the wrong values.
More İnformation and example project : http://make.robimek.com/arduino-visual-basic-wireless-temperature-humidity-control/
About This Instructable
4,155views
18favorites
License:
Bio: Mechanical engineer, Entrepreneur, Maker, robotic systems expert and Robimek founder
More by sezgingul:Arduino Mini CNC Making Robot Hand With  Plastic PipesUse of Microphone Module
Add instructable to:
