Step 7Adding a servo
Building on the previous example now we'll add a servo that is tied to a second push button. This uses the Arduino Servo library to control the servo position. By changing the value in parentheses after the servo1.write code you can control how far the servo moves.
Copy and paste this sketch into your Arduino window-
* Example 3
* This example will blink two LEDs and then fade another LED when button1 is pressed and released
* and a servo will move after button2 is pressed and released
* Honus 2010
* Modified from Adafruit alternating switch code, http://www.adafruit.com
#include
Servo servo1; // creates an instance of the servo object to control a servo
int servoPin1 = 9; // control pin for servo
int ledPin1 = 8; // control pin for LED
int ledPin2 = 7;
int ledPin3 = 11;
int buttonPin1 = 14; // button is connected to pin 14 (analog 0 pin)
int buttonPin2 = 15; // button is connected to pin 15 (analog 1 pin)
int val1; // variable for reading the pin status
int val2;
int buttonState1; // variable to hold the last button state
int buttonState2;
void setup() {
servo1.attach(servoPin1); // attaches the servo on pin 9 to the servo object
pinMode(buttonPin1, INPUT); // set the button pin as input
pinMode(buttonPin2, INPUT);
buttonState1 = digitalRead(buttonPin1); // read the initial state
buttonState2 = digitalRead(buttonPin2); // read the initial state
pinMode(ledPin1, OUTPUT); // sets the LED pin as output
pinMode(ledPin2, OUTPUT);
void loop(){
servo1.write(20);
val1 = digitalRead(buttonPin1); // read input value and store it in val
if (val1 != buttonState1) { // the button state has changed!
if (val1 == LOW) { // check if the button is pressed
Serial.println("button just pressed");
digitalWrite(ledPin1, HIGH); // sets the LED pin HIGH (turns it on)
delay(500); // wait 500 milliseconds
digitalWrite(ledPin2, HIGH);
delay(500);
digitalWrite(ledPin1, LOW); // sets the LED pin LOW (turns it off)
delay(500);
digitalWrite(ledPin2, LOW);
delay(500);
// fade in from min to max in increments of 5 points:
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
// sets the value (range from 0 to 255):
analogWrite(ledPin3, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(40);
// fade out from max to min in increments of 5 points:
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
delay(40);
} else { // the button is -not- pressed...
digitalWrite(ledPin1, LOW); // turn off the LED
val2 = digitalRead(buttonPin2); // read input value and store it in val 2
if (val2 != buttonState2) { // the button state has changed!
if (val2 == LOW) { // check if the button is pressed
servo1.write(160); // rotate the servo to 160 degrees
delay(3000); // wait 3 seconds
servo1.write(20); // rotate to 20 degrees
servo1.write(20);
buttonState1 = val1; // save the new state in our variable
buttonState2 = val2;
Add Comment
