Most of the work in this came from getting the software to talk with the arduino and making a protocol for the data to be passed over. As for the hardware aspect all that I used was two servos (Parallax standard servo here.) A Sparkfun Arduino ProtoShield and an Arduino Duemilanove with ATMEGA328, but most of these parts can be substituted with similar items.
I thought up this project as part of a RC system, but setting up the communication took a lot of time. If anyone has any improvements, ideas, or bugs please feel free to comment.
EDIT: I wrote this awhile ago, just got to publishing it recently.
Remove these ads by
Signing UpStep 1Things you may need...
1. Arduino board (you choose)
2. two (or one) servos
3. jumper wires
4. Visual Studio 2008 Express -- link (optional)
5. Arduino IDE -- link
Sorry Linux and Apple fans, my program only runs on windows for now, but you can still manually send serial commands to the arduino without changing the code.
However, as far as power is concerned.. it'll work as long as the servos aren't too big for the 5v regulator on the Arduino (although, even then it's not a bad idea to use a larger regulator separate from the Arduino's to run just the servos, I've seen some odd things happen when the servos get to be too much for the Arduino's power supply, but not enough to actually shut it down)
If it does need a larger regulator, you can use something like a LM317 regulator to supply power to the servos (or another regulator, I just happen to like the 317)
Thanks, Matt
right after the Serial.begin(38400)?
When the port is opened it will usually reset the arduino so it should work when the port is first selected.
I will update the current file here to support this.
--matt
