Arduino controlled window for cat
 by saastamo
Featured
I am submitting this instructable to the Arduino challenge. Please remember to vote!
My neighbor had a little problem with his cat. It want's to go out and back inside too frequently. Usually he opens just his kitchen window and let's the cat in/out. Usually the cat stays only short periods outside and want's soon to come back inside. And then again out and back in. Okay, he could just let the window open, but here in Finland it can be easily -30 C (-22 F) in winter, so this is not a good solution.
We decided to build a microcontroller to the window to open and close the window automatically. Arduino controls a strong servo motor, which moves the window. It has three proximity sensors to sense where the is cat is.
Step 1: Parts list
Main parts:
1 pc suitable power adaptor to juice the Arduino (input voltage 7-12V dc)
1 pc Arduino microcontroller (or equivalent *duino)
1 pc strong servo motor to move the window. I used Towerpro MG995 Metal Servo with Gears (10kg Torque).
3 pc Pololu 1134 carrier board with Sharp GP2Y0D810Z0F Digital distance sensor 10 cm
1 pc "Third hand" to hold the sensors
1 pc cat (operator)
Misc. parts:
some wire
suitable casing
small window hinge
some metal parts to fix the servo to the window frame, screws, etc
Tools etc:
Solder & soldering iron
Computer & usb cable to program the Arduino
joecabezas says: Mar 17, 2013. 6:35 PM
nice!
can you post a video working?
CatTrampoline says: Mar 28, 2012. 11:53 AM
One little thing, how does the sensor distinguish between the housecat and other small animals?
What happens when a varmit shows up at the window? I guess they don't have raccoons or possums in Finland, but what about neighbor cats & magpies?
saastamo (author) in reply to CatTrampolineMar 28, 2012. 11:09 PM
Yes, there is no way how a simple IR detector could distiguish varmit and a cat. However, the alternative of having the window open all the time this is definitely better. A wild animal has also even steeper learning curve to use automatic window. The windows sudden movement is sure to scare wild animal away at least for some time.
If needed, it could be arranged that the cat cas a RFID tag and then the window opens only when right RFID is around. In our case this was not an issue. Good point, though.
drewgrey in reply to saastamoMar 30, 2012. 11:30 PM
Whisker recognition software.......
CatTrampoline says: Mar 28, 2012. 11:48 AM
Outstanding! I will not let our cats see this, lest they increase their demands. Supervisor Cat Her Majesty Holly is also a black tuxedo kitty.
AntoineMeillet says: Mar 28, 2012. 7:03 AM
Very nice project :)
A video would be great !
10er512 says: Mar 27, 2012. 11:14 PM
Sorry for a dumb question, but do you really always need the arduino board to be able to construct prototypes? or can the software be used to program a custom circuit?
I'm new with this arduino thing.
saastamo (author) in reply to 10er512Mar 28, 2012. 2:43 AM
Exellent question: of course you can make custom circuit. The easiest way to program the microprocessor though is to program it in developement board "Arduino". You can even take the controller away after the programming to your circuit and buy a new microcontroller into your developement board. Look the link below for ideas.
http://www.instructables.com/id/DIY-Arduino-or-The-DIY-Duino/
WWC says: Mar 26, 2012. 5:53 PM
Very clean installation. Great project.
sofiadragon1979 says: Mar 26, 2012. 1:51 PM
LOL I misread that & read it as "arduino controlled cat" LOL.
saastamo (author) in reply to sofiadragon1979Mar 26, 2012. 2:39 PM
Lol! Not yet so advancved! It would be totally new approach to the problem!
sofiadragon1979 in reply to saastamoMar 26, 2012. 3:36 PM
LOL I could never do that to my cat master.
rimar2000 says: Mar 25, 2012. 1:39 PM
Your cat is like my Heidi!
Awesome project!
saastamo (author) in reply to rimar2000Mar 26, 2012. 2:48 PM
Greetings to Heidi! Thanks!
PeckLauros says: Mar 26, 2012. 7:24 AM
Nice instructables!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
