3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino controller DIY
My first Instructable is on how building your own Arduino controller!
You can build it on a breadboard, but i prefer to solder my own. For use with projects. This board wil not be able to program a ATmega chip. I use my original arduino for programming and use mye homemade boards in my projects. This reduces the cost!
Check out www.taydaelectronics.com for cheap components and fast delivery.!.
Step 1What you need for the build
I used the following parts.
1x Solderboard
1x 28 PIN socket for the ATmega chip
1x ATmega 328 chip, preloaded with Arduino bootloader
1x 7805. 5V regulator
1x 10K resistor
1x red LED w/ 2x 100 OHM resistors
1x green LED w/ 1x 470 OHM resistor
2x 10uf capacitors
2x 22pf capacitors
1x switch (reset)
1x 16MHz Crystal
Wire for soldering
PINheaders
4 comments
Mar 2, 2011. 12:24 PMquigath says:
I want to something like this but with an external regulated +5v power supply.
How would the power connections change in that case?
Feb 22, 2011. 4:55 AMAgeingHippy says:
A circuit diagram would be a good addition to your instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:KvalePale
