Introduction: Arduino Dual Ultrasonic Liquid Level Meter With Integrated Website
This project allows you to monitor the level of 2 containers filled with liquid. The levels can be shown on a website. The example below has one sensor connected by wire, and another sensor connected wirelessly by XBee.
The website allow you to configure the minimum and maximum levels (for a full and empty tank), so the level can be shown in percentage. Also the tcp/ip settings can be configured.
This project was created at the second Belgian Arduino Jam Gent by:
- Jo3ri C (http://www.jo3ri.be/) Check this site for more information about the included webserver
- Erik DC
- Wim DB
http://www.arduino-jam.org/
- Erik DC
- Wim DB
Step 1: Main Module
The main module is composed of an Aduino Ethernet board (or an arduino with Ethernet shield).
Directly attached is the URM37 ultrasonic sensor from DFRobot (ethernet cable is used as extension lead). The URM37 is used in TTL mode, so only 4 wires are need (2 for power + 2 for data)
Also on the main board is the XBee Explorer (https://www.sparkfun.com/products/9132), that takes care of the 3.3 to 5V conversion, and receives the data from the wireless sensor.
Step 2: The Wireless XBee Sensor
Since we had some 'barebone arduino' (ATMEGA 328P-PU with bootloader) laying around, we choose to use this for the remote sensor.
Xbee's DIN and DOUT are connected to D0 and D1 on the arduino, so the build--in Serial can be used.
The sketch running on it is very simple, it reads out the URM37 (connected to pin 2 and 3), and transmits the distance in cm through serial to the Xbee.
int URPWM1=2; // PWM Output 0-25000us,every 50us represent 1cm
int URTRIG1=3; // PWM trigger pin
unsigned long urmTimer = 0; // timer for managing the sensor reading flash rate
unsigned int Distance1=0;
void setup(){ // Serial initialization
// Sets the baud rate to 9600
PWM_Mode_Setup();
pinMode(URTRIG1,OUTPUT);
Serial.begin(9600);
void loop(){
if(millis()-urmTimer>1000){
urmTimer=millis();
PWM_Mode();
void PWM_Mode_Setup(){
pinMode(URTRIG1,OUTPUT); // A low pull on pin COMP/TRIG
digitalWrite(URTRIG1,HIGH); // Set to HIGH
pinMode(URPWM1, INPUT); // Sending Enable PWM mode command
void PWM_Mode(){ // a low pull on pin COMP/TRIG triggering a sensor reading
digitalWrite(URTRIG1, LOW);
digitalWrite(URTRIG1, HIGH); // reading Pin PWM will output pulses
unsigned long DistanceMeasured1=pulseIn(URPWM1,LOW);
if(DistanceMeasured1<49000){
digitalWrite(13,LOW);
Distance1=DistanceMeasured1/50; // every 50us low level stands for 1cm
} else {
Distance1=0;
digitalWrite(13,HIGH);
if ((Distance1 > 3) && (Distance1 < 400)) {
Serial.print(Distance1);
Serial.print("-");
PWM_Mode_Setup();
Serial.begin(9600);
void loop(){
urmTimer=millis();
PWM_Mode();
} else {
Distance1=0;
Serial.print("-");
Step 3: Configuration
The website on the arduino allows you to configure the TCP/IP data, as well as the minimum / maximum levels of your tank.
