Introduction: Arduino Flashing LED Lamp
A simple RGB LED underglow for a lamp. You can get the lamp from walmart. It has a clear plastic cover for keeping pencils and stuff in it. It is very easy and takes maybe five minutes, but improves the look of room(even though my room is messy)
Step 1: Arduino
Parts:
lamp
arduino uno
9v battery & cord
rgb led
male&female jumper wires
Step 2: Wires
Put yellow wire into GND on Arduino, and into v on the RGB. Put the green into pin 13, and into g. Put blue into pin 12 and into b. Put red into pin 11 and into r. If you don't have the same RGB LED as I do, you can just use a bread board, or put the LEDs ends straight into the arduino.
Step 3: Code
This is the code I used. It is just a blink without delay sketch.
int green = 13; //declare/initialize led colors to their pins
int red = 12;
int blue = 11;
void setup() {
//initialize pins
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100);
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
digitalWrite(12, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(12, LOW); // turn the LED off by making the voltage LOW
digitalWrite(11, HIGH); // turn the LED on (HIGH is the voltage level)
delay(200); // wait for a second
digitalWrite(11, LOW); // turn the LED off by making the voltage LOW
delay(10); // wait for a second
delay(50); // wait for a second
delay(20); // wait for a second
delay(1000);
delay(10);
delay(200);
delay(1000);
delay(100);
delay(2000);
digitalWrite(11, LOW); }
About This Instructable
479views
7favorites
License:
More by Jaxton Maez:Arduino flashing LED lampEasy RGB LEDMini Pencil
Add instructable to:
