Step 1: Background talk
On the other hand, I had a spare NES 'generic' controller bought in a flea market that was working perfectly.
I thought about using a microcontroller to convert the serialized signals in NES joystick to parallel signals required by Atari 2600, but then I wondered that if instead of a custom microcontroller board I could use an Arduino. So other people without many skills in electronics could assemble their own adaptors with easy.
Step 2: The 'big' Circuit
Bill of Materials:
- 1 Arduino (any version will do)
- 2 DB-9 Male connectors. One for the NES 'generic' Controller and another to the test dongle
- 1 DB-9 Female connector, to plug into the Atari.
- 5 Leds for the test dongle
- 5 resistors 330 Ohms 1/4 Watt for the test dongle
- A buch of wires
Of course is it possible to reuse the old Atari Joystick cable instead of the DB9 female plus wires.
It is also possible to cut the NES controller cable and connect directly to the Arduino, but you should identify the wires in the cable.
Step 3: Programming the Arduino and doing some tests
// Play on ATARI 2600 with NES Controller By Danjovic, 2012
// Compiled on Arduino 0.22
ATARI 2600 Joystick
Activates sequentially the following directions from an Atari 2600 Joystick
UP, DOWN, LEFT, RIGHT, TRIGGER
CONNECTIONS ON ATARI JOYSTICK
Function DB-9 Arduino AVR
UP 1 Pin 2 (PD2)
DOWN 2 Pin 3 (PD3)
LEFT 3 Pin 4 (PD4)
RIGHT 4 Pin 5 (PD5)
+5VCC 5 +5V +Vcc
TRIGGER 6 Pin 6 (PD6)
GND 9 GND GND
NES Controller
Contains a CMOS Shift Register (CD4021). Data change on raise border of Clock
button sequence as below.
latch ___---_______________________
Clock _______-__-__-__-__-__-__-__
Data xxxA B SL ST UP DW LF RG
The NES controller is powered by the Arduino.
DATA 2 Pin 8 (PB0)
LATCH 3 Pin 9 (PB1)
CLOCK 4 Pin 10 (PB2)
+5VCC 7 Pin 11 (PB3)
GND 8 Pin 12 (PB4)
// adapt to your hardware config
#define POWER_VIA_PORT_B3_B4 1 // use port pins B3 and B4 as power supply
#undef int
#include <stdio.h>
/* Atari Joystick port connections */
int Up_Pin = 2;
int Down_Pin = 3;
int Left_Pin = 4;
int Right_Pin = 5;
int Trigger_Pin = 6;
/* NES Controller connections */
int Data_Pin = 8;
int Latch_Pin = 9;
int Clock_Pin = 10;
int PWR5V_Pin = 11; // power
int PWRGND_Pin = 12;
void setup ()
/* Initialize Pins connected to Atari 2600. */
//Pins are set as inputs to emulate open collector outputs
pinMode(Up_Pin, INPUT);
pinMode(Down_Pin, INPUT);
pinMode(Left_Pin, INPUT);
pinMode(Right_Pin, INPUT);
pinMode(Trigger_Pin, INPUT);
// Initialize Latch outputs as zero, thus to activate a pin the direction
// shall be changed to Output
digitalWrite(Up_Pin, LOW);
digitalWrite(Down_Pin, LOW);
digitalWrite(Left_Pin, LOW);
digitalWrite(Right_Pin, LOW);
digitalWrite(Trigger_Pin, LOW);
/* Initialize Pins connected to NES controller. */
// Pin set as Inputs/Outputs as required
pinMode(Data_Pin, INPUT);
pinMode(Latch_Pin, OUTPUT);
pinMode(Clock_Pin, OUTPUT);
// Initialize NES controller signals
digitalWrite(Data_Pin, HIGH); // enable pullup resitor
digitalWrite(Latch_Pin, LOW);
digitalWrite(Clock_Pin, LOW);
// Check wether to power the NES joystick or not
#ifdef POWER_VIA_PORT_B3_B4 // power supply for NES controller via port B3 and B4
PORTB &=~ _BV(PORTB4); // Ground
PORTB |= _BV(PORTB3); // Vcc
DDRB |= _BV(PORTB3) | _BV(PORTB4); // make outputs
delay(100); // wait for things to stabilize
#endif
// Perform a clock cycle on NES controller Clock line
void do_clock (void){
digitalWrite(Clock_Pin, HIGH); // Raise clock pin
delayMicroseconds(10); // pauses for 10 microseconds
digitalWrite(Clock_Pin, LOW); // sets the pin off
delayMicroseconds(50); // pauses for another 10 microseconds
Here is our main loop. It issues a latch pulse then starts to reat the state of the buttons.
The Atari joystick port pins are set according with the state of the bits read from shift
register inside the NES controller.
void loop ()
digitalWrite(Latch_Pin, HIGH); // Raise the latch signal
delayMicroseconds(30); // hold it for 30 microseconds
digitalWrite(Latch_Pin, LOW); // Return latch signal to low level
delayMicroseconds(10); // hold it for more 10 microseconds
// Process Button A (remember: A zero means button pressed)
if (digitalRead(Data_Pin))
pinMode(Trigger_Pin, INPUT); // Unassert pin (zero means button pressed)
else
pinMode(Trigger_Pin, OUTPUT); // Assert pin
do_clock(); // A clock pulse is generated at the end of each bit
// Process Button B // Both NES button generates a trigger to Atari
else
do_clock();
// Skip Select Button
do_clock();
// Skip Start Button
do_clock();
// UP direction
pinMode(Up_Pin, INPUT); // Unassert pin
else
pinMode(Up_Pin, OUTPUT); // Assert pin
do_clock();
// Process DOWN direction
pinMode(Down_Pin, INPUT); // Unassert pin
else
pinMode(Down_Pin, OUTPUT); // Assert pin
do_clock();
// Process LEFT direction
pinMode(Left_Pin, INPUT); // Unassert pin
else
pinMode(Left_Pin, OUTPUT); // Assert pin
do_clock();
// Process RIGHT direction
pinMode(Right_Pin, INPUT); // Unassert pin
else
pinMode(Right_Pin, OUTPUT); // Assert pin
do_clock(); // Kinda useless, but kept to mantain the pattern
// After read all buttons, wait 10 milisseconds before next reading
delay(10);
Step 4: Playing!
Enjoy your console with the new controller.
Not Nice
Visit Our Store »
Go Pro Today »
