3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino-powered A-10 stick grip remote w/Emergency Party Button!
  • last photo ←
I came across Plama2002's "Emergency Party Button" build a while back and wanted something similar for my bar. I also had an old USAF B-8 stick grip from an A-10A that I picked up in my previous life. I figured instead of just being a conversation piece, I could put it to good use as a remote control for my AV system. What I came up with is a master control box that:
- Controls my SAT TV, music server and iPod dock via my Audio Visual Receiver (AVR)
- Controls the overhead lighting in the bar and the components of the Emergency Party System.
- Looks really cool sitting on the bar!
It uses two Arduinos: one for switching and IR transmission, and one to wirelessly control the X10 devices.
This build is not really that difficult as both the Arduino and X10 applications in this project are really pretty simple. You just need to figure out exactly what you want yours to do and adapt it. Since I'm writing this ex post facto I'll try to make up for the lack of step-by-step photos with thorough explanations. Sorry I don't have the circuitry sketched out but there's not much to it - we're mostly just hooking up buttons with pulldown resistors, just like in the Arduino tutorials. There are a few slightly more complicated things going on but I'll be sure to explain them as we proceed!
Step 1Gathering Stuff
Gathering Stuff
This build is really a few builds within a build, and uses mostly optional components which you can choose to incorporate or not.
The basics:
- Soldering iron, flux, solder and plenty of small gauge hookup wire. I think I used mosty 24g or 26g
- Hot glue gun, epoxy, wire shrink wrap and wire ties as desired
- A project box, cigar box or something big enough to fit all the components into. I used a cheap, old cigar humidor.
- B-8 stick grip or similar control interface. It's up to you what you use - the interface could be as simple as a cheap array of switches or buttons
- 2 Arduinos (I used Uno's), one to run the IR remote control stuff and one to run the X10 stuff. You may be able to use just one if you know what you're doing. This was my first real Arduino project and I didn't :-).I also used protoshields to make these circuits permanent, but breadboarding will do!
-Switches. I used two DC toggle switches with 'missile guards' and a cheap Chinese key switch for effect. Since this is a custom build to your own preferences, use whatever you like!
For the Arduino remote control:
-IR remote control circuit to capture IR signals from your remote and decode them. See here
- 38kHz Infrared (IR) Receiver Module
- An IR LED or two to transmit the codes to your device(s)
For the Party Button
X-10 CM-17A Firecracker dongle
X-10 transceiver such as TM751 Mini Transceiver Module
X-10 lamp and appliance (3-prong) modules, receptacles and light switches as required
- Arduino with BroHogan's X10 Firecracker remote library installed.
- Old female serial plug that you can tear apart
Light effects for the box:
- LED's. I used a couple of LED arrays I found online that run off 12v DC and an LED 'cyclon' kit I had lying around that will run off 3v from the arduino. You'll need IR LEDs too, and couple of regular ones.
- A couple of transistors to provide switching from the Arduino to any external devices that run on their own power supply. I used a Tip120 connected to the Red Alert siren and amp, a Tip120 connected to the 12v Police Flashers, and a 2N4401 to connect the IR LED's to the Arduino. I'll explain all this as we go on.
Sound FX for the box:
-A simple siren kit or something similar. I used a cheap 'Red Alert' circuit using 555 timers
- An LM386 amplifier circuit or similar, if desired. I wanted the alarm to be load so I used the amp.
-Speaker
Power:
A 12v li-po pack powers the LED "police flashers" on the outside of the box, a 9v pack powers the X10 Arduino, a set of two 3.7v li-ions powers the IR remote Arduino, another set of 2 li-ions powers the IR LED''s themselves, and a regular 9v powers the siren. The LED cyclon on the top of the box is powered directly with 3v from the Arduino board.
I know there is a more efficient way to power the whole thing, but I built it in stages and as I got each part of it running, I didn't feel like taking the time to re-engineer the power system. I could probably run the whole thing off of the 12v li-po pack but I'm too lazy to figure out how to do it. Plus I had a bunch of rechargeable 14500 and 10440's (AA and AAA size li-ions batteries) in stock and there's plenty of room inside the box, so space was not a problem.
9 comments
Dec 16, 2011. 10:12 AMbyrdy says:
Spike, you are smarter than I thought you were. Too Cool!! Needs a trigger that will give your dogs collar a light zap..........and if properly trained...... he could bring a beer to your party..
Oct 31, 2011. 3:50 AMPyroMonger says:
This is effing incredible. Great job!
Nov 8, 2011. 4:46 PMmikeasaurus says:
I love how there's a 'party' button, awesome!
Oct 31, 2011. 2:15 PMplasma2002 says:
I see I'm going to have to step up my game. Haha, awesome job man! Love the cylon chaser.
Also, I think I found my new motto:
"The degree of awesomeness is directly proportional to the amount of eye roll from my wife"
:D
Oct 30, 2011. 6:53 AMvags says:
go HAF !!! :))
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:spikec
Just a guy who likes to build cool stuff...
