loading
Step 2: Wire Up the Relay Board to Arduino
I used GND/PWR 5 on the arduino to go to the VCC/GND on the relay board - this gives it the power it needs to flip the relays.
Next choose which OUTPUT pins on the arduino you want to drive the relay switches, those get hooked up to the IN pins on the end of the relay board, and to the OUTPUT pins on your arduino.
At this point you should be able to turn pins on from the arduino and see the relays activate, they have a red status light so you know if they are "on"
The left-most 2 pins coming out of each relay are the 2 to use, those 2 will be 'closed' when the relay is 'on'
From the AC power, go in to the first pin on each of the first 3 relays you want to use.
On the second pin go out to the traffic light.
When the relay is on it should supply 120v across the relay to the christmas light bulbs in the traffic light.
<p>Nice Job! and a good presentation, I have been working one myself and plan to post it when I get the all drawings finished. </p>
<p>Hi,</p><p>I&rsquo;m irinakim and I&rsquo;m work in the Wiznet.</p><p>Thank you for using our product.</p><p>We are collecting so much data using our product.</p><p>And I will post the this project on our Web site.( <a href="http://wiznetmuseum.com/" rel="nofollow">http://wiznetmuseum.com</a>)</p><p>Can I post your product on our Web site?</p>
About This Instructable
8,886views
12favorites
License:
Bio: Just building businesses and gadgets
More by troyanderson:HTTPole (REST API Pole Display) Arduino powered mini traffic signal - monitor your repair shop!
Add instructable to:
