Arduino Powered Servo Control - I Made It at TechShop
Published
Introduction: Arduino Powered Servo Control - I Made It at TechShop
Servos are incredibly useful in making "things" move. But in order to make that thing move you need to control it somehow. Luckily, arduino makes this incredibly easy to do and can be done with something as a potentiometer. The potentiometer turns and the servo can follow this rotation to it maximim bounds. I made this at TechShop and you can too.
http://techshop.ws
Step 1: Materials
Arduino Uno
Servo (5volt, really any small size will work)
10k ohm potentiometer
breadboard
wire
usb cable
Step 2: Circuit
This circuit is just about as easy as easy gets with an arduino powering it.
The servo has three wires, Vcc, ground, and data. Connect Vcc to power, ground to ground, and data to pin 3. The data pin is important because it needs to be a pin with PWM or pulse with modulation control. Not all arduino pins have this capability. On the uno they are marked by a " ~ ".
Connect the potentiometer to power and ground. Connect the third leg to analog pin 5. This creates a variable voltage divider for the arduino to read.
Circuit complete.
Step 3: Code
This is the code for the servo to follow the potentiometer
#include <Servo.h>
#define POT_PIN 5
#define SERVO_PIN 3
Servo myservo;  // create servo object to control a servo
void setup()
  myservo.attach(SERVO_PIN);  // attaches the servo on pin 9 to the servo object
void loop()
  int val;
  val = analogRead(POT_PIN);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
Run that and Viola! You can now control a servo with a potentiometer.
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    I tried the same but my services doesn't move properly and its also shaking .what to do?
    that I can do to convert 2 PWM inputs (rc servo) to 5Vdc analog?
    Nice job!
    nice, you should post a video of it working!
