Arduino Voice Control
61,706
87
60
Posted in TechnologyArduino
Introduction: Arduino Voice Control
Step 1: Part list
Step 2: The Access port
Step 3: Arduino
Step 1: Part List
Hardware:
- Voice recognition module V2 (Ebay ~22$)
- USB to TTL module (~2$)
- Arduino nano (~6$)
- Breadboard
- 3 Led
- some wire
Software:
- Serial tool (Im using Accessport, link in video description)
Step 2: Teach the Voice Module
This module can learn 3x5 voice command. (3 group, each group with 5, max 1300ms long command)
To teach, we need a serial tool: Accessport.
- Start the program, plug in the module with the USB to TTL board.
- From the Monitor/Ports menu, select the voice module. If not see, click refresh.
- In settings menu use this settings:
Baud rate: 9600
Parity bit: NONE
Data bit: 8
Stop bit: 1
Send format: HEX
Receive format: Char
Other settings as default.
- The first time, we need to choose "common" or "compact" mode.
Im using "common mode".
- For this, send "0x36" to the board.:
Just type after the "00000000" AA36, and click "Send".
If its ok, above you can see "common mode" text.
The modul now ready to learn.
- To teach the commands, send "0x11" to the module. (this mean, we record to the first group).
Type after the "00000000" AA11, and click "Send".
- After appear the "START" word above, tell the first command, repeat if ask.
"Finish one" mean, you done with the command, immediately afterwards ask the 4 other command in same way.
"Group 1 finished" mean you are done, close the app, unplug the module,
Step 3: The Arduino Code
- After disconnected the voice module, connect the arduino, and upload this code.
Or download from my google docs. (Link in the video description)
- Leds connected to the pin 9,10,11. (use resistor)
- After code uploaded, unplug the arduino, connect the voice modul:
VCC to 5V
GND to GND
Rx to Tx
Tx to Rx
- Power on the arduino, wait 3-5 sec until ready.
- Talk to your arduino :)
Code:
int redPin = 9;
int greenPin = 10;
int bluePin = 11; byte
com = 0; //reply from voice recognition
void setup() { Serial.begin(9600);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
delay(2000);
Serial.write(0xAA);
Serial.write(0x37);
delay(1000);
Serial.write(0xAA);
Serial.write(0x21);
void loop()
while(Serial.available())
com = Serial.read();
switch(com)
case 0x11:
digitalWrite(redPin, HIGH);
break;
case 0x12:
digitalWrite(greenPin, HIGH);
break;
case 0x13:
digitalWrite(bluePin, HIGH);
break;
case 0x14:
break;
case 0x15:
digitalWrite(redPin, LOW);
digitalWrite(greenPin, LOW);
digitalWrite(bluePin, LOW);
break;
2 People Made This Project!
  • Casting Contest
    Casting Contest
  • Microcontroller Contest
  • Make it Move Contest
Hi, after you teach the board the commands, does the arduino need to stay connected to the PC, or just powered?
60 Comments
In the program,how the switch case option is fixed as 11,12,etc?
Can I upload 1 command by 4 speakers, so that 4 different speakers can give single command to arduino (like 'ON')?
Could this be used to spin a motor a set number of rotations? So, say "Spin" and it could be programmed to spin a motor a number of times?
Yes, but need stepper motor for precision stop.
I am trying to train my vr3 module by using the library in GITHUB. When I used a sample code vr_sample_train, I am getting an error as time out. how can i solve this?
Me too having the same problem
could we use v3 for arduino mega??????
One think I do not understand: how can you manage each voice command to select a different pin out ( e.g: pin 0) and pin level (e.g: high voltage level / binary `1`) on arduino and/or on the voice recognition module? For example the red, green and blue LEDs are connected to different pins and different voice commands control different pins and thus different LEDs. Sorry, I am so confused. Could you show me a step-by-step instruction. Thank you very much!
Hello, When I plug in the
Voice recognition module and USB to TTL module
and try to access it through the accessport or coolterm, it doesnt detect anything. I've tried this on another computer and the same thing happened. Is there a driver I have to install?
Have you been able to find solution for that, I couldn't get mine working. :((( Red light is blinking continuously and no response to access port.
Programmed my voice module and uploaded the code to the Arduino but when I turn the Arduino on the voice module just blinks the red light and it won't go off any ideas how to fix that?
I got the module to recognize my voice. It was the microphone. But now I connect the module again to record new commands and I get @A@B and nothing else as response from the module in the serial app
I cant get my module to recognize voice commands. I get the START but when I speak, I get No Voice no matter how soft or fast or loud or slow I speak.
What is the principle used to recognize voice in this module........
i was wondering .my pc cud not recognize my module.. is there a need for drivers to install or what?
No driver need as i know. In the system/hardware cannot see opened port when plug in the module?
