This is how I use my Arduino UNO and the Maxuino patch in Ableton Live to control LED's via MIDI. This is the most basic setup for the circuit and gives examples on various MIDI controllers that can use this setup to control LED's. I am a mad musicianist!!! These are the basic 4 ideas that I use in musical performance with Ableton Live's: Max 4 Live. This is my FIRST INSTRUCTABLE!!! I can't wait to keep contributing to this society of makers and doers! I hope that someone will find this instructable useful for their own musical needs!!!
This is the instructable video. The links to the devices used are below!!! Watch out for the performance video next!!!
We have a MIDI keyboard, MIDI drum pad, and MIDI knobs to control our LED's. We also have some MIDI data sent to our LED's via the Maxuino patch; from our Ableton generated drums. So here she is!!!!
maxuino:
http://www.maxuino.org/?p=58
envelope follower:
maxforlive.com
(: all original music and circuits :)
Austin
i was thinking of using a audio line in jack
The problem is the envelop follower (I assume). Would you be able to explain your audio and/or midi track set up, and how to use the follower in more detail?
thanks a lot
The part that I don't understand is how to set up the envelope follower.
so far I've recorded the sounds the MIDI notes produced in Ableton. If I was to switch to "arrangement view" in Ableton I would be looking at a recorded track.
I'm gonna try and use your patch for the envelop follower, how do set:
"track - device - parameter" and then "map"?
according to your tutorial all I should have to do is click "map" and then switch immediately to Maxuino and click the parameter (for example the slider on 3)
they should link and then my LED should blink on and off according to the notes I've recorded?
I guess it's the envelop follower patch that I'm missing?
thanks a lot for the help.
To use the envelop follower as I did; on a MIDI instrument OR Audio track; here are the steps:
Create a blank MIDI track for the Maxuino patch.
Build or wire your Arduino for LED action.
On any track that produces Audio, place the envelop follower AFTER your instrument. (If the track is audio clips only, place it AFTER or BEFORE effects for different results) Note: record MIDI compositions/parts and flatten. Then add into Session view for Audio clip only LED following.
On your track from the previous step, click MAP on your envelop follower.
Then immediately go to your Maxuino patch and choose the PIN fader you wish to use for PWM.
Now go have fun.
Audio can be used to PWM LED's, motors, servos, or anything else.
Immediately go to your Maxuino patch, and click the parameter you wish to modulate.
audio is a good plan, I'm gonna work on audio playback. Once I get this, I'm gonna try and figure out how to run everything with MIDI (if possible)
whoisadamwest@gmail.com
I'm still trying to get these lights. I'm pretty sure it's that envelope follower that you're using!
thanks man!
Thanks man, great project
Know of any free ones?
Otherwise set up a free, and unimportant, email address. Then post it here as a comment. I'll then send what you need there. BEWARE of MASSIVE SPAM!!!
