Arduino/Android- 28BYJ 48 Stepper Motor Control Using the HC-06
5,439
13
7
Posted
Introduction: Arduino/Android- 28BYJ 48 Stepper Motor Control Using the HC-06
Hello world! Today i made a simple app to turn one 28BYJ 48 stepper motor on and off, it just rotates to one direction. I will make a app to control the curtains of your house next, with the same motor. If you want the source code of the android app just ask! I will ask a very small favor in return. Go to the next step for the Schematic, Parts list & code.
Step 1: Schematic, Code, Parts List & APP
Just wire it up like the Schematic and it should work after uploading the code.
Make sure you disconnect the HC-06 when uploading the code. Other wise the arduino becomes confused.
Parts list.
  1. Arduino uno, I used the RobotDyn Uno which has 7 analog pins instead of 5.
  2. HC-06 Bluetooth module.
  3. 28BYJ 48Stepper motor With the ULN2003 driver board
  4. Jumper wire set. MM/FF/MF
  5. Android phone and our APP.
Get the APP on GOOGLE PLAY
Good luck!
To find out how to rename your HC-06 & set PIN + change baud rate. Follow step 2 (optional)
Step 2: How to Change the Name of Your HC-06
What is needed?
1 x USB to TTL microcontroller programmer to connect to your HC-06
How to connect the Programmer?
VCC to VCC
GND to GND
RXD to TX
TXD to RX
Lets get started...
  1. connect the USB TTL programmer to the HC-06
  2. Plug in the USB and open up The Arduino IDE
  3. Open the serial monitor.
  4. Type "AT" without quotes. You should see a respond in the Serial monitor saying "OK"
  5. Type "AT+NAMExyz" Sets the module name to “xyz” (Replace xyz with the name you want.) response should be OKsetname.
  6. Type "AT+PIN1234" Sets the pin to 1234 (replace 1234 with your desired pin) respond should be OKsetPIN For more info on changing baudrate etc. i included a PDF file. Good luck!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
5 Comments
Hello,
Good job! Can you send me this app source and the app source for curtain control, please
thanks
Hello Can I have the APP and APP source code sent to me? Reference, thank you! 1309082105@qq.com
nice work !! you can also use voice commands and make laser turret !
Hi, Thanks! Nice project you made. I made another APP to control curtains, or whatever you want to control with a stepper motor. follow the link https://www.instructables.com/id/ArduinoAndroid-BLUETOOTH-28BYJ-48-Stepper-Motor-Cu/
Check out my other instructable. as i said i was going to make another app to control your curtains. SO here it is. https://www.instructables.com/id/ArduinoAndroid-BLUETOOTH-28BYJ-48-Stepper-Motor-Cu/
