Arduino/Android - BLUETOOTH RGB LED CONTROL ANDROID APP
Published
Introduction: Arduino/Android - BLUETOOTH RGB LED CONTROL ANDROID APP
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I ma...
Hello world! Today i made a app to control a RGB Led module with a Android Device. Contact me for the Open source code of the APP.
NOTE: If you bought a Common Anode LED connect it to 5v
I used a Common Cathode Led which needs to be connected to GND. The KY-019 Module from keyes.
Follow the next step for the Schematic, Code, parts list & APP
Download the APP on google play! Ask me for the Open Source Code! Contact@arduinosensors.nl
Simple Instructions to change the APPs RGB Pallette.
When clicking the IMAGEbutton the RGB rgb pallette will change to a Square instead of a circle.
When holding the IMAGE button the RGB rgb pallette will change back to a circle.
Step 1: Schematic, Code, Parts List & App.
Just wire it up like the Schematic Upload the code and it should work!
Parts list.
  1. Arduino uno, I used the RobotDyn uno.
  2. HC-06 Bluetooth module
  3. KY-016 Or any RGB Led
  4. Jumper wire set MM/FF/MF.
  5. Android app & Phone.
Good luck!
To find out how to rename the HC-06 Module and HC-05 Go to my other Instructable here
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    5 Comments
    how to save the result data to eeprom? so that when arduino power replug the previous color is still same
    plz explain the arduino code
    can you share the android app code with me plz
    i hope that you explain how the code (both arduino + apk) is working.
