Arduino(nano) Clap Switch
4,470
55
9
Posted
Introduction: Arduino(nano) Clap Switch
in this tutorial i will be showing you how to make an Arduino clap switch
let's get started!
All you have to do is-
clap once to turn the LED on
and
clap again to turn the LED off
Step 1: ORDER YOUR COMPONENTS:
the components required for this build are:
1xArduino(Any arduino will work)
1x220 ohm resistor
1xLED(Any colour)
1xmicrophone amplifier circuit (variable)
1xBreadboard
some jumper wires or single strand wires
that's all the components!
Now let's move to the next step!
Step 2: CONNECTIONS:
sorry guys, I didn't had the SCHEMATIC so i will tell you all the connections,
here are the connections:
Connect A0 pin of the microphone Amplifier to digital pin 12
Connect GND pin of the microphone amplifier to the GND pin of the Arduino nano
Connect VCC pin of the microphone amplifier to VCC pin of the Arduino nano
Connect one end of the 220 ohm resistor to GND pin of the arduino nano
Connect the other end of the 220 ohm resistor to the cathode(smaller leg of the LED) of the LED
Connect the anode(bigger leg of the LED) to digital pin 12 of the Arduino nano
THAT'S ALL THE CONNECTIONS!
Step 3: THE CODE:
pinMode (micpin, INPUT);
pinMode (ledpin, OUTPUT);
void loop() {
if (digitalRead (micpin)==HIGH)
{ if (digitalRead(ledpin)==LOW) { digitalWrite (ledpin, HIGH);} else digitalWrite(ledpin,LOW);
delay(1000);
Step 4: SUCCESS!
After some small connections and small code we finally get success!
all you have to do is-
clap once the LED turns on
clap again the LED turns off
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
8 Comments
and how do you get that rounded pice (sensor i think)?
I found some mistake in your instructable:
You wrote: "Connect A0 pin of the microphone Amplifier to digital pin 12 [...] Connect the anode(bigger leg of the LED) to digital pin 12 of the Arduino nano"
Both devices connect to pin 12, but on the photo the A0 pin of the mic connect to D10 pin of Arduino.
It looks the begining of code is lost. I think it could be this way:
int micpin=10;
int ledpin=12;
void setup() {
void loop() {
if (digitalRead (micpin)==HIGH) {
} else {
delay(1000);
No, you will need a relay to do that. That is the subject for my another tutorial. Wait for my next tutorial(the better version of clap switch).
i know but can u plzz sent me the circuit diagram and the code plzzzzzzzzz.My e mail is lokanathmishra12@outlook.com
I'm currently working on that project.
I will send you once I'm done;)
can you plzzz give me the list of requirments.i am already having arduino uno r3,12v 4 channel relay,some jumper wires,and adaptor.anything else required???????
THANK YOU
