Armouring a bicycle tire for final puncture protection. by m a r i a n o
Contest WinnerFeatured
Puncture protection tires are available (quite expensive) which have either an inlay of thick elastic material or a web of strong fibres. Liners can also be placed between the tire and the tube. An alternative to buy one of this products is to cut the bead of old tires and mount them as liners inside of the tires to be protected. Check this site for more information: http://bicycling.about.com/od/bikemaintenance/a/avoiding_flats.htm
All this systems give some amount of protection. However, a piece of glass that is big enough will make his way through any of the above protections. I propose you here a cheap and hopefully effective alternative. Of course this armouring increases rolling resistance and weight. However, these effects cannot be noticed in my 20 inches folding bicycle and I really don't care.
Para ver la versión en español seguir este enlace.
Material  needed:
- old tires, thinner than the tires to be protected,
- self-retracting tape measure;
- an old brake cable
Step 1:
Cut the bead of the old tires.
Step 2:
Cut the tape. The length should be a bit longer that the diameter of the tire, the extremities will overlap.
Step 3:
Cut the central knobs in order to make place for the tape. It may also work if you ignore this step.
Step 4:
Separate one wire from the cable.
Step 5:
Sew the tape to the old tire knobs with the wire. Alternatively you may try with dental floss or some other strong yarn, but it risk to be cut by the tape.
Step 6:
Place the old tire inside the tire to be protected.
Step 7:
Mount the tire and the tube in the wheel and inflate.
The tire is formed even without air. With an strong tape or many metres of tape it would even be possible to cycle without air at all!
sidmarx says: Dec 30, 2012. 4:05 AM
Steel tape works great until it rusts, breaks into sections, and pokes a hole in either tire or tube, whatever it's next to.
m a r i a n o (author) says: Dec 31, 2012. 12:42 AM
I'm sorry to hear that. Was the steel tape painted? I hope that the paint on my measure tape keeps rust away a bit longer. May be an aluminum tape would be a better idea.
The brake wire may rust as well, it would be better to fix the tape with other means.
sidmarx says: Jan 7, 2013. 8:26 AM
Yes it was. My present meth. has been working for months now, with no internal friction flats either. Here's how: For a 20" tire get 20" of tire tread with beads cut away. Add a 24 or 26" mountain bike tube with valve cut out, pinching the tire tread to feed it into the tube. Pull the whole strip in and overlap the excess tube over the other end, making a liner ring. (the tread strip alone would wear against the inflated tube & eventually cut it.)
Caveat--my first try was with duck tape, not tube, and that also cut the inner tube, believe it or not....
m a r i a n o (author) says: Jan 23, 2013. 12:24 AM
Good method. You should publish an instructable on that.
EsquireJoe says: Jul 7, 2012. 2:50 PM
If you don't have an old metal tape measure lying around, you could also try using some of those old aluminum blinds. They're about the same width/gauge.
m a r i a n o (author) says: Jul 16, 2012. 11:30 PM
Good idea. May be the tape is better because its resilience is higher.
alxriz says: Jul 16, 2012. 12:39 AM
did you put the inner tube in contact with the sharp-edged tape? or added at least electrical tape inbetween?
m a r i a n o (author) says: Jul 16, 2012. 11:12 PM
The tape is sandwiched between tire and the old cutted tire used as lining. The tube should not be in contact with the tape or with any other sharp object.
golddigger1559 says: Jul 3, 2012. 8:48 AM
what if you stack more tires inside? that way you could have a semi-solid tire, then youll never have to worry about a flat again
Prof. A. Z. O_Trope says: Jul 5, 2012. 12:15 PM
If you ride on very smooth surfaces, that's fine. But on any irregular surface, it will make for an incredibly jarring ride. That's why the original bicycles had those enormous tires -- pneumatic tires had yet to be invented, and a reasonably smooth ride required a very large tire diameter, especially on the dirt and cobblestone roads prevalent in that era. Only when Mr. Dunlop came along and perfected what is more or less today's tire technology could tires be reduced to modern sizes and still offer a comfortable ride.
With today's polymer technology, it's probably possible to make some sort of solid composite with similar performance, and such things may even be commercially available, but a solid-rubber tire is no better an idea today that it was in the 1800's.
killbox says: Jul 6, 2012. 8:09 AM
not only bumpy, but pneumatic tires, make for a much more efficient rolling over bumps. a solid rubber tire will resist going over every bump and all that energy is lost, where as the pneumatic tire will resit too then compress a little and then spring back returning alot of that energy.
Prof. A. Z. O_Trope says: Jul 6, 2012. 9:23 AM
Right you are! Those "bumps" are not only uncomfortable, a lot of energy goes into making them, and that energy can only be replaced by more pedaling. Whether it's a pneumatic tire or some kind of composite, it must have the feature of absorbing small bumps and then "springing back," as opposed to transferring the bump directly to the bike and rider, which is what would happen with a solid, essentially incompressible rubber tire.
Advar says: Jul 13, 2012. 12:06 PM
Maybe an inner core similar to dense pipe insulation...?
killbox says: Jul 13, 2012. 1:46 PM
those work as closed cell foam, so yes would help, but unless those cells are at or around 30psi its still going to ride like a bike with 2 flats i encourage someone to try it and bounce a normal wheel at normal pressure and any other method, and it it bounces 1/2 as high i would be surprised.
Advar says: Jul 15, 2012. 7:15 AM
Good point. Was also thinking of filling a tube with expanding foam insulation, but think that idea would fall flat...
(Sorry)
m a r i a n o (author) says: Jul 4, 2012. 12:14 AM
You may. A tube with pressurized air would still be needed, you need some kind of pressure to keep the bead interlocked with the flanges of the rim.
Performance of solid tires is known to be bad, probably worst than that of my armoured tire
Advar says: Jul 13, 2012. 12:08 PM
In-frelling-credible! Hitting dollar store tonight to try this out on spare bike...
hcbethel says: Jul 7, 2012. 3:49 PM
These all might work to reduce flats, but how many flats do you get? And they are easy to fix. I would gladly sacrifice the time to fix flats for the efficiency of a light tire.
m a r i a n o (author) says: Jul 7, 2012. 10:07 PM
Your point of view is very reasonable.
I use the bike for commuting, high performance is not relevant. Reparing a flat under the rain, on the night, by very cold weather, or when you are late to come to work is anoying. Without punture protection I used to have several flats a year, and I didn't like them.
germeten says: Jul 5, 2012. 8:42 AM
I don't understand the need for the wire/thread/tape. Putting a cut tire inside the one you want to inflate should do the job, the whole being held by inflation/friction, but THANK YOU for such a great idea.
m a r i a n o (author) says: Jul 5, 2012. 11:15 PM
You are right, as Zeroack said the cut tire (or an old tube) as a liner prevents about the 80% of punctures. The tape is there to prevent more than that.
J-Ri says: Jul 6, 2012. 8:55 PM
80%? I heard that 72% of statistics are made up on the spot :)
j/k, nice Instructable!
m a r i a n o (author) says: Jul 6, 2012. 11:42 PM
Thank you.
You are right. I have no idea where the 80% comes from. Sorry, by writing a number my comment looks as statistics!
Percentages without "confidence interval" should not be seriuosly considered.
Aron313 says: Jul 5, 2012. 7:29 AM
looks like a good way to get a pinch flat.
m a r i a n o (author) says: Jul 5, 2012. 9:16 PM
You may be right. In my opinion nothing will happen so long the tape keeps sandwiched between the two tires. I'll tell you if a have a flat.
Aron313 says: Jul 6, 2012. 6:43 AM
Ok. Hope it works!
bluedragonlotus says: Jul 5, 2012. 8:38 AM
Quick question... does the tape measure make any noise when you ride on the newly armored tire?
m a r i a n o (author) says: Jul 5, 2012. 9:06 PM
One of the wheels makes a small periodical sound, provably where the tape overlaps.
Zeroack says: Jul 5, 2012. 9:33 AM
I've done something close to this. But used a old inner tube instead of a tire. While the doubled up tube doesn't stop all the thorns we have here in Nebraska it does stop about 80% or so. So the combo I've worked up is this - std tube w/4oz of slime sealant. Old tube with valve stem cut off as a liner. That usually does the trick.
mseba says: Jul 2, 2012. 4:24 PM
if weight is a factor then don't
caarntedd says: Jul 1, 2012. 6:20 PM
I will be doing this. A great practical way to re-use old stuff too.
m a r i a n o (author) says: Jul 1, 2012. 10:18 PM
Thank you. Please tell me if you do and if you made many kilometres without problems. That would statistically validate the method.
SelkeyMoonbeam says: Jul 1, 2012. 3:25 PM
You should enter this in the Bike Contest! http://www.instructables.com/contest/bicycle/
m a r i a n o (author) says: Jul 1, 2012. 10:14 PM
Thank you. I did, is pending moderator approval.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
