Arrow Pen!
Published
Introduction: Arrow Pen!
About: The top of my roof ----------------------------------------------------------------------------------------------- I don't think that this is a good idea. Come on! What could go wrong? I mean, you've got a ...
In this instructable, I will show you how to make something out of old, broken arrows.
Step 1: Materials
You will need:
A broken arrow
A pen
And some hot glue (optional)
Tools:
A hacksaw or other suitable cutting device
Sandpaper (high-er grit recommended)
Step 2: The Pen
The Pen will be gutted. Just pull on the front of the pen. If you need to, use some pliers, but try not to marr the plastic. Instead of just throwing the pen barrel away, try making this: http://kipkay.com/videos/just-for-fun/ez-airsoft-machine-gun/
Step 3: Assembly
Cut the arrow down to the size you would like it at, and sand the cut down so it doesn't cut your fingers while you are using the pen. Insert the pen guts into the arrow. Secure with hot glue (I didn't and it still works fine).
Step 4: Finished!
Congrats! You now have your own arrow pen! I didn't have my dremel and didn't cut iit down...Yet.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    3 Comments
    dont use a dremel. Use a pipe cutter. Cuts clean and knurls the edges in. And a lot safe. I did the same thing with crossbow bolts but carved the front piece out of wood. Its big enough to take a gel ink cartridge.
    I saw this has already been done by gnose, but i hadn't seen his before i published mine.
