I ended up with this quiver and I'm really happy with the design. It's very convenient while in the woods and lets me forget I'm wearing one at all. It has a twist that fits perfectly to my hip and down to my leg. This twist tilts the arrows a bit to the back side, thus ensuring that the nocks don't poke me in the back.
And additionally there is the option to attach a knife sheath directly to the quiver with chicago screws through the rivets on the side of the quiver. But that will come later...
Materials:
- Thick belt leather
- Rivets
- 5 Chicago screws
- 2 Cordura straps
- Leather glue
- Cutter
- Dremel (sanding and polishing bit)
- Drill
PS: My experience with leather is highly limited. In fact it's the second time I'm working with it. So there might be better ways to do some things. Feel free to make it much better!
UPDATE1: The pattern for the three leather pieces is now attached. But be careful, the first page is format A3 (2 sheets of A4) and the second and third is A4. The distance measurements are in mm (metrics. Greetings from Europe...). However, even if you print it the wrong size, you can use the angles on my template and together with the distance measurements you can easily make your own pattern and adapt it to your needs.
UPDATE2: Instructable user LAZY GLEN did an amazing job and traced my crappy sketch and made a DXF file and a PDF of the dxf file. The measurements are very close to what I used on my quiver. Many thanks to Lazy Glen!
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
The armguard was simple. I used Photoshop to scale it correctly. Then I printed it, cut it, and traced it on the leather. I need to use a recently purchased leather punch to clean up the holes; the drill made them a bit ragged and puckered. I used brass rivets and lace hooks as hardware.
The quiver was bit problematic without using a commercial printer to generate a template. Since I had the measurements, I just needed to replicate the angles. I simply folded along the relevant lines at key points to create the angles and used the paper as a protractor on the leather. The curved arrow guide at the top was more of a challenge. To make a long story short, I figured its zenith and nadir relative to a centered "Y" axis and an "X" axis running across from the beginning of the curve (a real bitch, since I'm not the engineering type). Then I basically eyeballed it (yep, definitely not an engineer).
Please note: for left-handed archers, the quiver template must be a mirror-image of the original. Left-handers will wear it on their left hips; the arrow guide and leg twist will be reversed.
I've ordered leather stamping tools and a swivel knife, so I can tool the next armguard and quiver with fancy patterns.
As for the leather, maybe you have someone that works with horses. They use decent thick leather for the tack and bridle. Maybe you get lucky.
http://www.instructables.com/id/Archery-leather-armguard
I also thought about making one in a similar fashion but with individual pockets to suppress rattling. I don't know exactly how I would do it with lacing, but with rivets and/or sewing it should make a nice quiver!
I saw a link in the side bar for a PVC over the shoulder back sling, I may try to do both. The plotter paper 36" cardboard tubes should be perfect.
Thanks again.
Glen
Thanks for the ideas.
