Art Deco Fireguard for Log Burner
3,462
53
7
Published
Introduction: Art Deco Fireguard for Log Burner
About: I make things and share videos of the builds on youtube.
In this instructable I walk through the process for creating a custom metal fire guard to go around a log burner.
I built this as I have young children in my family that were coming to visit over christmas, and I wanted to avoid them accidentally touching the log burner which gets extremely hot in use. The idea was just to provide a simple barrier that would keep the children away whilst still allowing access to the log burner to add fuel.
For this project you require:
Welder - I used a MIG welder. (clarke 150en)
Bench Grinder - to shape the round bar to get good contact at the join points
Angle grinder - unless you are a much better welder than I am, you'll want to clean things up with an angle grinder
Mild steel flat bar stock - 20mmx3mm
Mild steel round bar - 6mm
Step 1: Watch the Build Video
read on for the steps
Step 2: Make the Frames
This project requires 3 identical frames, that go around the 3 exposed sides of the log burner. Simply determine the size of your panels (mine was dictated by the size of the granite hearth the burner sits on and the height of the burner itself. I wanted all 3 to be the same size.
Cut the flat bar stock to the relevant lenghts and make some simple 90 degree joins.
It can be helpful to have a 90degree angle clamp for this, though one is not necessary.
Step 3: Determine the Design
For my guard I went with an art deco design based off the light fittings in our room. The advantage of this design were the straight lines and symetrical pattern. In theory though you could come up with any interesting pattern you like.
Step 4: Make Scale Drawing of Your Design
Draw your design in 1:10 scale on graph paper. This means that you can measure in mm and cut in cm.
This means you don't need to do any clever math or figuring out, just draw the design you want inside a box at the 1:10 scale of your frame size. Then you can measure each line in your drawing, and it if it is 17mm long in the drawing, you need to cut some round bat to be 17cm long in real life. In my design I repeated the same layout 3 times, this was easier than doing something different each time. It also means that every time you setup a tool to cut a length you need, you can cut 3 which saves you time.
Step 5: Cut the First Few Pieces and Start Welding
Unless you are perfect, it probably doesn't make sense to cut all the pieces then start welding. Because little inaccuracies can build up, and welding can cause flex which you may need to account for in adjusting the length of some pieces.
So start with a few parts of the main central pattern. It's helpful to have some welders magnets to hold things in the arrangement you want whilst you weld the joints.
As you cut each piece of steel rod to go into a place in your design, hold it against what you have so far, and use a marker pen to draw the angle that the pieces will join each other. You can then take the rod to the bench grinder and grind the ends to match the required angle.
This will give a much better join with more contact area for your welding.
Step 6: Grind Your Welds Flat
Once you have completed cutting the lenghts and welding your pattern in place, take an angle grinder and clean up all the welds.
This will make the finished item look better (unless you are a great welder) it will also act as a small strength test to your welding, if you have messed up any joins it will probably come apparent at this stage and you can redo them.
Step 7: Make Feet
To allow each panel to stand nicely you'll want to put them on feet. You can make a basic foot from more of the flat stock, as pictured.
Once you've got them attached nicely you can again use an angle grinder to clean up the look of the welds.
I placed my feet 10cm in from each corner
Step 8: Make Hinges/connectors Part 1
The idea is for the 3 panels to join together to form a box around the log burner. So they need some way to be joined, but ideally not permanently. You still want to be able to take the panels apart.
This is a simple 'hinge design'
Cut 3 short lengths of the flat bar stock. Take 2 pieces and clamp them together and drill a 6.5mm hole through them on a drill press - remember to use a slow speed and some cutting lubricant for drilling through steel.
You can them weld these into a U arrangement. Which can then be welded to the side of the front frame. You require 4 of these, one for the top and bottom of each side of the front panel.
Measure from the centre of your drill holes to the rear edge of that piece, this is the minimum that your pins need to protrude from the other frames in order to fit down the barrel holes you've made.
Step 9: Make Hinges/connectors Part 2
You now need to make some 'pins' that will slide into the drilled holes of your hinge barrels.
Cut a short length of 6mm rod at a 45 degree angle. Then weld back together twisted to form a 90 bend.
Use the measurement from the previous step to determine how far out from the frame your pins need to protrude before the 90 degree bend.
Align the front frame with the side you are working on and place your pin into the hole of the barrel piece in order to figure out the right place on your frame to weld it. This ensures correct alignment since you're welding it in situ.
You can then slide the panels apart by lifting the pins out of the holes.
Repeat the process for the other side and you should now have 3 panels which can be connected to form a barrier around your log burner.
Step 10: Check the Fit
Before painting, quickly check that everything fits right around your log burner and can be assembled in place.
Step 11: Use Metal Paint to Finish
In my example I've painted the panels with black metal paint. It took 3 coats to get good coverage.
Step 12: Finished!
Sit back and enjoy a fire with the family.
To see me make this one, check out my video
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    7 Comments
    This is truest beautiful! You did a great job and I don't see a thing wrong with it. I don't see where you entered into any contest? I would certainly vote for you!!!
    Great job.
    I like this a lot I always thought I needed something to keep my son and dog away from my wood stove. great job .
    This really looks nice. But then when it comes to making fire or cleaning the ashes it seems as being quite a hindrance?
    It's actually not bad. With it in place the door can still open enough to feed new wood in.
    When starting out I can pull it forward perhaps 15cm which is enough for the door to fully swing open. Obviously it is a barrier, that's kind of the point. But I've not found it to be a problem.
    Maybe if you had constructed the hinges to make the front part a door and fixate the side parts to the wall?
    I did consider something like that. However I felt it might make things too complicated. Also I don't intend for this to have to permanently be in the living room. Only when we have children around that run a risk of accidentally touching the hot stove. But it would certainly be an option.
