Arthur's Batch Calculator
3,260
Posted in TechnologyElectronics
Introduction: Arthur's Batch Calculator
Welcome to my batch calculator.  I made this on my own and did not copy this calculator from other sites.  This Instructable will show you how to make a Batch Calculator and you can also download a .exe file for this.
Step 1: The Batch Code
Copy this code into notepad or notepad++ and save as Calculator.bat.  The .bat is a must.  Then save as "all files" to your desktop.
@ echo off
title Arthur's Batch Calculator
color  1D
echo -------------------------
echo Welcome to my Calculator
echo Made by Arthur
color 1A
echo =====        =====
echo =====        =====
echo =====        =====
echo.
echo.
echo ==              ==
echo ==              ==
echo  ==            ==
echo  ================
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo.
pause
cls
:top
color B4
echo List of Calculations
echo.
echo +=+
echo -=-
echo /=/
echo *=x
echo.
echo.
echo.
echo Enter Calculation
echo.
echo.
echo.
set /p sum=
set /a ans=%sum%
echo.
echo = %ans%
echo ---------------------------------------------------
pause
cls
echo.
echo.
echo Previous Answer %ans%
echo.
echo.
echo.
echo.
goto :top
pause >nul
Step 2: The Running of This Calculator
When you use this calculator use the # pad it is much easier.  This calculator dose not divide decimals sorry.  The * = multiplication.  The / = division.  The - = subtraction and the + = addition. To get the answer press enter
Step 3: The .exe File
Download the .exe file here.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Microcontroller Contest
    3 Comments
    I did not make a batch calculator but I did make a Visual Basic Script Calculator.
    Code:
    dim num1
    dim num2
    dim equ
    num1 = inputbox("Enter First number")
    equ = inputbox("enter your variable ie. (/ * - +)")
    num2 = inputbox("enter second #")
    if equ = "/" then msgbox(num1 / num2)
    if equ = "*" then msgbox(num1 * num2)
    if equ = "-" then msgbox(num1 - num2)
    if equ = "+" then msgbox(num1 -- num2)
    this one is mine enjoy! :)
    @echo off
    title vCalculator Omega
    goto typeset
    :errblockfinal
    cls
    goto val
    :errblockval
    color 0C
    echo.
    echo Please enter a number!
    pause
    set a=
    set b=
    if %valtilt%==1 goto display
    if %valtilt%==0 cls&goto secondint
    :errblock
    color 0C
    echo Incorrect math type!
    pause
    :typeset
    cls
    color 0B
    echo ____________________
    echo +,-,/, or x ?
    echo.
    echo (Type one below and press enter)
    set functiontype=
    set /p functiontype=:
    if not defined functiontype goto :errblock
    if "%functiontype%"=="exit" exit
    if "%functiontype%"=="+" set typedisplay=Addition&goto begin
    if "%functiontype%"=="-" set typedisplay=Subtraction&goto begin
    if "%functiontype%"=="/" set typedisplay=Division&goto begin
    if not "%functiontype%"=="x" goto errblock
    if "%functiontype%"=="x" set typedisplay=Multiplication&set functiontype=*
    :begin
    cls
    if "%functiontype%"=="x" set functiontype=*
    color 0A
    set a=
    set b=
    set c=Only enter 9 digits per prompt, if missing operand above you did not enter anything. Only use whole numbers!
    cls
    :display
    cls
    echo %typedisplay%
    echo.
    :firstint
    color 0A
    echo Enter first integer.
    echo _____________________
    echo.
    set /p a=Integer:
    if not defined a set valtilt=1&goto errblockval
    if not %a% gtr 0 set valtilt=1&goto errblockval
    :secondint
    color 0A
    echo Enter second integer.
    echo ______________________
    echo.
    set /p b=Integer:
    if not defined b set valtilt=0&goto errblockval
    if not %b% gtr 0 set valtilt=0&goto errblockval
    cls
    set /a c=%a%%functiontype%%b%
    if %functiontype%==* set functiontype=x
    :val
    echo %a%%functiontype%%b%=%c%
    echo.
    color 0E
    echo (y/n) or (quit)
    set /p functiontilt=Would you like a new math type?
    if not defined functiontilt goto errblockfinal
    if /i "%functiontilt%"=="y" goto typeset
    if /i "%functiontilt%"=="n" goto begin
    if not "%functiontilt%"=="quit" goto errblockfinal
    if /i "%functiontilt%"=="quit" goto :EOF
    Or this one:
    @echo off
    :a
    echo Enter Equation
    echo.
    set /p MATH=Equation:
    set /a RESULT=%MATH%
    echo %RESULT%
    pause
    cls
    goto a
