Step 3Drill Holes For Cotter Pin Screw
That said, it makes the assembly very stable, so I think it's worth it. Place your mounting bracket where it will go on the handlebars and mark the top and bottom of the tube where the machine screw will go through. If you use the conduit bracket I used, it has two small holes conveniently located on the top and bottom -- simply mark where they are!
Then, drill a hole at each mark using a suitably-sized bit -- 11/64" worked well for the 8-32 x 1.5" machine screw I used.
Add Comment
