Step 2Prep the backpack
Cut the top of the backpack frame off just above the highest crossbar. I used my Dremel for this and it took about 15 minutes to cut both sides. I then sanded the raw edges smooth. These will form part of the hinges that let the wings flap.
Next cut the inner frame in half using the drill cutting wheel or metal snips or whatever seems best - the cut edge won't show so it can be messy. Bend the pieces further at the existing right-angle bends, until each is a long thin U shape and the long bits are parallel. When you're done, the cut end should fit through the nylon cap (R) into the cut edge of the main frame. These pieces will form the verticals that the wings attach to - the shoulder joint, as it were.
Thanks much. This is SUCH A COOL project1
Thanks for the compliment! Post a pic when you're done!
