3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Articulated Wing Framework
Step 3Cut the balsa pieces
  • last photo ←
Since there are so many parts, I have labeled the first picture with how I'll refer to the bits throughout. The hardware is labeled in the Tools & Materials step.
On a large piece of paper, draw three 'bone' shapes X, Y, Z. The important dimensions are the lengths from the middles of the hinge holes. I put masking tape over the back of the paper before I cut out the patterns; this made them much easier to trace onto the balsa.
bone X:
top hole to middle hole: 12-3/8 inches
middle hole to bottom hole: 6 inches
bone Y:
top hole to middle hole: 18-3/8 inches
bone Z: top hole to bottom hole: 6 inches
and it should be about as long, overall, as bone Y
Trace the patterns onto the balsa, two of each. You should be able to fit 2 pieces per balsa sheet if your bones are shaped like mine (or smaller). Using the Xacto knife, cut the pieces out (a very small, fine saw would probably also work but my jigsaw just tore up my test sample). A good technique for this is to trace the lines several times, cutting deeper each time. Ripcuts are very easy; crosscuts are slightly harder as the balsa tries to compress. Cut only a little deeper each time. Don't worry too much about accuracy, once the shapes are cut out in general it's easy to carve the edges down as if you were whittling.
Lay each pair of identical pieces out with the pattern on top and line them up well. Drill pilot holes where you marked the hinges.
8 comments
Jul 27, 2011. 5:45 PMCosplayProps says:
how many inches across is the widest part of your bone Y Ms. Rachel?
Jul 11, 2009. 3:42 PMunisis5285 says:
Hello Rachel, I just wanted to start by saying I am SUPER IMPRESSED with these wings. I am in the process of making a set and have a question about fitting the balsa wood patterns. The Y Bone piece says: top hole to middle hole: 18-3/8 inches middle hole to bottom hole: 6 inches But as my pieces of balsa wood are only 24 inches long, they are not long enough for the total length which is 24 3/8 in just between holes not including the extra space needed between the holes and the end of the wood. Am I missing something in the directions? My brain has been a little foggy lately!
Aug 22, 2009. 5:23 AMablefox says:
Hi Rachel, I'm about to embark on a steampunk version of your design and am very excited! I think what may have thrown unisis off is that the materials list says " (B) 3 pc of 24" x 4" x 1/4" balsa wood." It seems like it should be 36" instead...
Aug 29, 2009. 8:22 PMablefox says:
Aug 9, 2009. 11:56 AMdieter laser says:
Hi, nice work. maybe im blind but I couldnt find the lenght of the two balsa dowels. greetz
Jul 31, 2008. 1:52 PMSparksfromfire says:
Hello Rachel, or anyone else who has completed this instructable, Could you post a bit more on the construction of the balsa to dowel hinge. I cannot quite figure out what you've done there. I see the parts laid out in your photograph, but I do not see how they connect. Thank you, Sparks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
242
Author:rachel
I'm a founding member of Noisebridge (https://noisebridge.net), a hackerspace in San Francisco, and Ace Monster Toys (http://acemonstertoys.org/), in Oakland. If you're in the area, stop by and say h...
more »
