Step 3Shaping and Baking
About an hour before baking, pull the bin of dough out of the fridge, remove the lid, and dust the surface of a corner of the dough with a bit of flour. Dust your pizza peel (or cutting board, or rimless baking sheet) as well.
Make sure your hands are well floured. Reach into the bin and pull out a grapefruit-sized hunk of dough, cutting it off with the serrated knife.
GENTLY pull the outer surface of the dough around to the bottom of the ball, forming a gluten "cloak" around it. Less is more here. Don't manhandle or squeeze the dough. This should take less than 30 seconds. Don't worry about what the bottom looks like.
Place the loaf on the peel and let it sit for about an hour. It won't rise much at all, and this is normal and O.K.
Half an hour before baking, turn the oven on to 450 Fahrenheit, placing the stone on the middle rack, and the broiler pan below it.
After the loaf has rested for an hour (don't worry if it hasn't raised much), fill a cup with 1 cup of hot water from the tap and set it beside the stove. Dust the top of the loaf with a bit more flour and slash it a few times with the serrated knife.
Slide the loaf onto the stone in the over and immediately pour the cup of hot water into the broiler pan. Shut the door quickly, and set the timer for 35 minutes.
When the bread is done, thumping it on the bottom with your thumb will sound hollow, and as it cools there will be a surprisingly loud crackling sound from the crust.
If you plan on slicing the bread or eating it later, let it cool fully before doing so, but I'll bet that you won't be able to resist tearing into it immediately!
My variations: I used an airbake-type cookie sheet, and I used unbleached flour (unbleached is what I had). I did use the roasting pan and water. Decent oven spring, amazing crust top and bottom, and great crumb.
Thanks so much for his Instructable! I LOVE making bread, but didn't often because of the work involved. Now? Bread every day!
Anyway, I made another loaf today using a $1.50 "pizza stone" (unglazed red tile) from Home Depot. I had to handle the loaf again to get it off the sheet it was rising on, but the spring was STILL better than last night. (Do I correctly credit an "older" dough and a stone instead of cookie sheet?)
The only problem that I have is while slashing the bread a few time right before putting in the oven, I do not get the neat cuts. I use a serrated knife, flour it too.
1. Used table salt, and used 3tablespoons of it.
Also, I have some questions:
1. Why don't you have to give the yeast sugar? I mean I can understand it feeds on the flour anyway, but I've always been taught to proof it first.
2. Will the dough in the container continue to rise slowly over a period of time while in my fridge?
3. Is it a problem to divide this recipe?
4. Is it really better to weigh the ingredients rather than measure them with the scoop and swipe method?
Whatever happens, I'm going to continue to bake my own bread, and I'm buying the book.
I'm sure I will have more questions/comments.
2) Rising pretty much stops in the fridge, once the dough is cooled. It will even fall after two or three weeks, at which point it makes great pizza crust or flatbread.
3) Divide away. It is easiest to divide if you are weighing the ingredients.
4) Weighing is far more precise, and I find it to be faster. I place my container on the scale and weigh the ingredients directly into it, "tareing" the scale between ingredients.
"INGREDIENTS:
6C. Lukewarm Water (I use tap)
3 Tablespoons Active Dry Yeast, or four packets (I use Red Star)
3 Tablespoons Kosher or flake salt (I use Morton's)
13C. All-Purpose Unbleached Flour (I use whatever is on sale)
DON"T actually measure out the flour yet.
I actually only use about 2T. salt. Some people prefer less, and others more, but 3 T is a good starting point.'
Bold is just for this reply.
