Step 3: Drawing on your CD
1. The basic of this technique is to have a still, smooth hand. Take some diazepam to stop your shaking (if you have any, hehe). Press play on the Walkman. Place the pen SOFTLY on the CD, do not press too hard or the CD will run slower, but make sure you keep its speed steady and draw slowly. While drawing, look at the line you draw. If the line flickers, keep drawing on the same spot, moving the pen slowly up and down the area you want to draw on. You can move further once the line doesn't flicker. If you leave the line flickering, once you stop the CD from spinning, only a fraction of the line you tried to draw will appear.
2. You can change colors, mix them, or etch different lines with different sizes and colors. You can even draw a rainbow on your CD, which looks cool.
3. There is another technique I discovered while experimenting on these CDs. If you keep drawing a line, for about 15 seconds, you can place your finger on the line, soflty, and keep drawing, with the CD running. Lift your finger and place it back again on the line as long as you like. NOTE: once you do this, there will be ink from the pen flying all around your workplace, so have a water solution or alcohol and a towel nearby.
The resulting design will be the following: lines that will come out of the original line you were working on.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
