Introduction: Assassin's Hidden Blade (Manuel)
this is a manual hidden blade
Step 1: Gather the Parts
Make sure you have 2 belts, 3 socks (no ankle socks), 1 Retractable toy sword (Mine is the toy rapier from Indiana Jones And the Crystal Skull) A hot glue gun, Scissors, A knife ( to cut the sword)
Step 2: Cut the Socks
Cut the socks at the ankle the top part will be used for arm protection (Otherwise the cut blade peices scrape your arm)
Step 3: Cut the Blade
Cut the area at the second slider down to cause a two peice blade make sue the wider peice is shorter than the end peice
Step 4: Cut the Belts
Mesure the belt around your arm and give at least 6 inches of extra
Step 5: Hot Glue the Belts on to the Blade
make sure and place 1 at the top of the exterior part and one at the bottom DO NOT GLUE THE BELT ONTO THE INNER BLADE
Step 6: Equip
belt it on and assassinate your friends if built correctly the blade will retract upon assassination
Step 7:
Step 8:
comment if you have any questions
