3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Assemble a Universal PCB
Step 11Required Assembly: Numbered Resistors
Now we will place and solder the three numbers resistors on the UPCB.
The two labelled '22' require a 22 Ohm resistor. Using the same steps as the pull up resistors, bend the resistor, insert it through the holes so the resistor lays flat against the board, bend the legs to secure in place, solder, and trim the extra legs.
The last numbered resistor is '1M', requiring a 1 Mega Ohm resistor. Repeat the same steps as above using the appropriate resistor.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Toodles
