3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Assemble a Universal PCB
Step 26Optional Assembly: Sixteen Pin Button Connector
This option is for those who did NOT choose the NeoGeo Converter Option. The step will install a 16 pin IDC connector that will connect the 8 buttons via a ribbon connector. This step is completely optional. You can choose to solder the button wires directly to these holes if you wish, but using an IDC connector like this is much cleaner and makes any stick maintenence a ton easier.
The orientation of the header doesn't truly matter; you just need to be aware of which pins deal with which buttons. To make things easier for describing the installation, it is recommended that you orient it so the small key faces the center of the board like in the pictures below. The instructional for installing the UPCB into an arcade stick will assume this.
Install the IDC connector into the spot labelled with the names of buttons (SEL, STA, JAB, etc. THey are the first three letters of the button that goes to that pin). The connector will hang a small bit over the endge of the board; this is normal.
Solder one of the corner pins, and check the placement of the connector. The connector should rest as flat as possible against the board. If you need to adjust it, melt the solder on the corner and readjust. If it looks good, solder the opposite coner and repeat to make sure it is in place. If it looks good, solder the other 14 pins in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Toodles
