Step 27Optional Assembly: Piggyback Option
Start with the IC socket. Just like the 40 pin socket we did in the beginning, there will be a notch on one end of the socket to mark the first pin. You will see a matching notch in the silk screen on the UPCB. Place the IC socket so that the notches match, and solder a single corner pin. Check to make sure the IC is lying flat. If the socket needs adjusting, melt the solder and adjust. If the socket looks good, solder the opposite corner and check again. Once the socket has two soldered pins and the socket is resting fully, go ahead and solder the other 12 pins.
Next we'll do the two 16 pin IDC connectors, into the spots labelled 'DC Connector' and 'X360 Connector'. The steps for both are identical. Place a 16 pin IDC connector into the spot marked, with the small key notch facing the inside of the UPCB. Solder one of the corner legs in place. Check to make sure the IDC connector is resting flat against the UPCB. If the conenctor needs adjustment, melt the solder and adjust. Once it has cooled, solder the opposite corner pin, and test again. Once the connector is flat against the board, and two pins are soldered, go ahead and solder the other 14 pins. Repeat for the other IDC connector.
Add Comment
