3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Assemble a Universal PCB
Step 6Collect Optional Parts
These parts are grouped by the options you've decided on. Please go through the list and add these to your shopping list.
Needed for the 'NeoGeo Converter Option':
1x Male DB-15 : Digikey # 215ME-ND
1x Female DB-15 : Digikey# 215FE-ND
Needed by everyone NOT using the 'NeoGeo Converter Option':
2x 16 pin IDC ribbon connector male: Digikey# HRP16H-ND
2x 16 pin IDC ribbon connector female:Digikey# HKR16H-ND
1x Ribbon cable for IDC connectors: Digikey# MC16G-5-ND
(If you to spend a little more to look cooler, you can use part number MC16M-5-ND instead, which is a multicolored ribbon cable instead of the plain grey one.)
Needed for the 'Six Pin Stick Connector Option':
1x 6 pin Molex KK header : Digikey# WM4204-ND
1x 6 pin Molex KK connector: Digikey# WM2004-ND
6x Molex KK crimp pins: Digikey# WM1114-ND
Needed for the 'Ten Pin Stick Connector Option':
1x 10 pin IDC ribbon connector male: Digikey# HRP10H-ND
1x 10 pin IDC ribbon connector female: Digikey# HKR10H-ND
Needed for the 'Piggyback Option':
1x 14 pin IC Socket: Digikey# ED3114-ND
1x 4066N analog switch IC: Digikey# 296-8329-5-ND
Needed for the 'Extra 2 LED Option':
2x 220 Ohm resistors: Digikey # 220QBK-ND
Needed for the 'Power LED Option':
1x 220 Ohm resistors: Digikey # 220QBK-ND
Needed for the 'Extra 2 Buttons Option':
2x 4.7KOhm resistors: Digikey # 4.7KQBK-ND
Needed for the 'Extra BiColor LED Option':
2x 100 Ohm Resistors: Digikey # 100QBK-ND
Needed for the 'ICSP Option':
(No additional parts needed for the 'Programming Button Option')
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Toodles
