3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Assemble a Universal PCB
Step 9Assembly - 40 pin IC socket
There are a number of components placed very close to the main IC socket, so we will make sure to put it in first. Slighlty nudging a resistor to rest next to a socket is easy when the socket is soldered and the resistor is not. It's a nightmare the other way around.
The IC socket has an indentation on one end, to mark which way the chip should be inserted. The white screenprint of the IC has a matching indentation. Make sure that these ends are together.
Solder only one corner leg of the IC socket at first. Once it has cooled, take a look at the socket from the side. You want to make sure the socket is resting fully on the PCB. If it isn't, melt the solder on that one leg, squeeze the board and socket together, let the solder cool, and check again. Once it is resting as flat against the PCB as it can be, solder the one leg in the opposite corner, and check again. If there is any space between the socket and board, fix it now.
Once both corner pins have been soldered, and the socket checked for proper placement, start soldering each and every one of the 40 pins. Some people try to go fast and use too much solder. Don't be that guy. Take your time, and do each pin right, making certain that the solder from each leg is not jumpering over to another leg, or a nearby via.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Toodles
