loading
Step 5: DC Port Bezel
Next we'll install the DC port bezel on the other end of the enclosure. The steps are similar to the USB port bezel:
Important: If your bezel says "L" and "R", you have a Beta kit. See the instructions here.
1. Make sure the enclosure is oriented as shown in the picture, with the 4 holes in the bottom plate up.
2. Without glue, try fitting the bezel.
3. If it doesn't fit, sand down the edges until it does fit
4. Apply a drop of glue to the middle of the wall sections. Again, don't put glue on the corners to avoid gluing on the top and bottom plates!
5. Place the bezel with "A" and "B" facing out, and closer to the bamboo bottom plate.
Nice job. How much was the kit? (I tried looking on the website but it wouldn't display the price.)
I love this model of wood!
Just got the kit and it works great! Any hints/ideas on waterproofing the panels? Wrap them (and the soldered connections) in saran wrap?
A dab of epoxy on the exposed bits will waterproof it just fine (and reinforce the solder). A slightly fancier alternative would be to use something like <a href="http://sugru.com" rel="nofollow">Sugru</a>.
Can you buy two battery packs (full kits) from your site and link them together? Charging both from the same solar panel, or panels? Something like output to input via cable?
Yes! All the parts you need to build a second battery pack can be purchased on our site, and you can indeed charge one battery pack from another. However, to do that, you'll need a USB to 2.1mm/5.5mm DC plug cable which we don't currently sell, but you can find one online for a few dollars (or make one yourself).<br><br>Send me an email at ryo-at-bootstrapsolar.com and I can give you a discount code if you decide to go this route.
I am part of the windowfarms open source community . Windowfarms just raised a quarter million bux on kickstarter. Anyways, they use aquarium bubble pumps to airlift water anything from 3 to 10 ft high through their hydroponic &quot;windowfarms&quot;. This is typically powered by ac current. There are dc versions of the bubble pumps available but they are rarely used. (I think they use 2 or 4 double A batteries.) If you could power these bubble pumps or reliably recharge them with your device, it would appeal to many of the windowfarmers. Many of them would really jump at this. The project leaders are big into cutting their carbon footprint so it would appeal to them too. So http://our.windowfarms.org/ <br>I did a test to try to find the limits of this weak airlift technique and I pumped easily 13 ft high without finding the limit! This means that your thing might have applications as a cheap well pump in 3rd countries if it powers a bubble pump with solar and DC. Another guy got 16 ft without finding th limit. <br>My experiment is at http://www.youtube.com/watch?v=lKtB1YKoMxk The airlift pump nano is based on a suggstion from Eileen (who is one of my youtube friends and who was mentioned in a ted talk by Britta Riley of windowfarms. )<br>So if you show your device pumping water higher than 16 ft by airlift as per the experiment, you might have some extra business!<br>Sorry for being long winded.<br>Brian
Neat! My kit can comfortably support up to about 1.5A (7.5W) of output, so it might be able to power a small pump. I'm not familiar with bubble pumps, but I'm guessing most of the heavy lifting is done by bubbles? Either way, if it could be powered by AA batteries, it sounds like there's a good chance my kit would be able to power it.
Congrats on a nice instructable and a great product. Having watched you put together this kit, I can attest to the fact that it is very well thought out. It would make a wonderful gift and &quot;starter&quot; project for someone interested in solar energy.
a quick remark regarding 'three leds=overheating' ... since you probably will never be monitoring the device at all times, a cheap piezo buzzer would be a cool addition.<br><br>i will try something when i receive my kit :)
Is the batter pack available to common consumers seeking replacements or are they spec'd for your project and a &quot;one of&quot; type thing. Will users have to come back to you for replacements? What do you expect as a useful life for the battery?
I have replacement batteries available for sale, and are priced much lower than other sources. For instance SparkFun sells a 6000mAh battery for $40, while I sell mine for $25.<br><br>But, as you point out, you won't be able to buy the exact same battery pack from other sources. However, you could replace it with any other 3.7V LiPo/Li-Ion cell that fits in the enclosure and has a JST PHR-2 connector (which is pretty common).<br><br>As for the lifespan, LiPo battery packs will retain approximately 80% of their capacity for up to about 1000 recharging cycles, but there's a lot of variability so I don't think that number is very useful. Since my kits come with 6000mAh batteries (which is about 4-5x the capacity of most cell phone batteries) it'll still give you a useful amount of capacity even if it deteriorates to 50%. Many commercial products in the same price range only come with 3000-4000mAh to start with.
Hi! I'm the guy at the Maker Faire that talked to you while you were cleaning up on Saturday after the Faire. <br><br>I just wanted to ask, where do you get the charging circuits?<br><br>I saw the circuits on your webpage but it was .sch and I can't read that file.<br><br>Can you save it in a different format?<br><br>Thanks. <br>
The charging circuits are based on an Open Source design by Adafruit Industries, but we had them made to our exact specs by a manufacturer in Colorado. The .sch can be opened using a circuit/PCB design program called Eagle, which is available for free.
Too bad I have Linux...
They have a Linux version: <br><br>http://www.cadsoftusa.com/downloads/?language=en
When I download, it won't open.
Eagle won't open, or the .sch file?
I can't get the software to open.
Instead of using the provided wood type screws, I would recommend on swapping them out with machine screws with nuts. While it might be tricky to get the nuts in there, you would end up with a better secured board.
Thanks for the comment... just a quick clarification:<br><br>I would encourage people to assemble the kits using the supplied parts first. In reality, the metal screws included in the kit do a pretty good job of securing the boards. The screws are actually slightly larger in diameter than the screw holes, so the threads bite into the soft metallic lining of the screw holes. Once assembled, the boards shouldn't wiggle, and should not pop loose even if the battery pack is dropped.<br><br>Would using a machine screw and nut be *more* secure? Absolutely. But most people probably won't need to swap out the parts from the stock configuration.
On step 2, between 6 &amp; 7, I'm thinking there should be something along the lines of recommending that the pieces should be clamped or taped until the glue is set. Sanding after the glue is set is a good idea too if you used a wood glue.<br><br>On step 4 and 5, I would probably use some painters tape on the bottom and top pieces so that when I glue in the USB and DC port panels, I guarantee I won't accidentally glue them to the top/bottom pieces. Once the glue is set, I could temporarily remove the top/bottom and remove the painters tape for a perfect fit.<br><br>On step 7 and 8, you write on 3 to secure the screws. Looking at the images, it appears you have wood screws directly tapping the circuit boards. Wouldn't it be better to use a machine screw with a nut (and maybe a nylon washer)? You designed it, so if you say the screw fits well I'll take your word for it! :-)<br><br>That's all my comments right now, hopefully I'll have a lot more when I receive my kit!
Thanks for your comments! I think those are all great suggestions. I tried to keep the process as simple as possible, though, I think there are ways to improve it. Perhaps you could post your suggestions as comments on the specific steps, so people can see them as they're going through the instructions.<br><br>As for the choice of screws, I think machine screws with nuts would definitely be more secure, but I was worried about people dropping tiny nuts into exposed circuitry and risk shorting something. Perhaps that's not really an issue since the circuits shouldn't be powered until the end... I'll look into this for future revs.
Wow, I always viewed Instructables in &quot;view all steps on one page&quot; and never realized you could comment on each separate step. I've added the individual comments to the steps so others could see them.<br><br>I'll probably replace those screws on the kit I receive since I might end up modifying it a bit. Thanks for putting this together!
After 6, I would recommend on taping or clamping the wood until the glue sets, then I would sand it to remove both the carbon residue and glue residue.
Yes, it looks kinda spammy ... although the open source aspect might be a loophole of sorts. That said, the design is really quite attractive. Nice job. I like the company profile page as well.
ok this looks like spam but it's also cool, it would be even cooler if the cover was a solar panel
Thanks for your comment!<br><br>I didn't put solar panels on the battery pack cover for two reasons:<br><br>1) A solar panel small enough to fit would not generate a meaningful amount of power, even using the most efficient cells commercially available.<br>2) It could cause the battery pack to heat up unnecessarily, which reduces the battery's lifespan and possibly even damage it.
About This Instructable
37,057views
158favorites
License:
Bio: Ex-software engineer, ex-mountain man, ex-disaster relief volunteer. Currently bootstrappin' a solar kit biz.
More by ryochiji:Assembling a BootstrapSolar Chi-qoo Solar Battery Charger Kit
Add instructable to:
