The project is housed at www.openthing.org/products/niftymitter
Remove these ads by
Signing UpStep 1What you need
- Complete Parts List [.xls]
- PCB Layout v0.24 [.png]
- The PCB source is designed for etching onto copperplate, using iron on acetate (such as that described here) or using Michael Shorter's laser engraving method described here [instructables].
- Circuit assembly diagram for etched PCB [.png]
You will also need the following tools:
Soldering iron, kit and solder.
Wire snips.
http://www.translocal.jp/radio/micro/howtosimplestTX.html
Or as a .png here:
http://niftymitter.googlecode.com/files/niftymitter%200.23%20electronics%20schematic.png
Or as a eaglecad .sch (not a very good one at the moment to be honest - please improve) here:
http://niftymitter.googlecode.com/files/0.23.sch
But there's an annoying buzz in the audio. I was wondering if it's something I did or if it's a known issue.
Otherwise I imagine it might be a tuning issue still, or the signal might be distorting if the input level is too loud, in which case you could try turning the volume right down on whatever your source is..
If it's your first transmitter, it's ok to play around with. (My first ones were of similar designs. That was at age 12, at age 17 i made my HAM license.)
But i don't think this one is of much practical use.
http://www.zen22142.zen.co.uk/Circuits/rf/lrfmtx.htm
or the main rf-page
http://www.zen22142.zen.co.uk/Circuits/rf/rf.html
The first circuit uses a capacitive diode for modulation, where your design uses the the varying capacity of the transistor for modulation. Secondly, there is a amplifying stage, which not only amplifies the rf, but also decouples the oscillator a little bit from the antenna.
But if you want something real stable, you need a crystal-controlled oscillator or a PLL circuit. These designs are much more complicated, but lately you find these small transmitters for feeding your mp3-player sound to your car stereo via FM-radio. So there are definitely some highly integrated circuits to do this in such a small size.(maybe it's easier to buy one of them, but then it's not home-brewed...)
exemple : 20 UF
