3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Assembling the Dragon Rider 500 for use with the AVR Dragon
Step 12PSU Add-On
PSU Add-On
The PSU add-on can be assembled in a couple of configurations. I decided to go with the option that allows for an adjustable voltage power supply.
1. Secure the voltage regulator to the board and solder it in place.
  • Place the heat sink over the copper pad on the PCB so that the mounting hole lines up with the hole in the PCB.
  • Place the voltage regulator in the heat sink so that it's mounting hole also lines up.
  • Use a pencil to mark the leads where they need to be bent at a 90 degree angle.
  • Use a pair of pliers to make a clean, 90 degree bend in the leads.
  • Place the head-sink and regulator over the board, add the screw and tighten the bolt to hold everything in place. Circuit boards are basically glass so do not over-tighten.
  • Solder the three leads of the voltage regulator in place and clip the excess.
2. Place the remaining components.
  • Be careful to align the two electrolytic capacitors correctly. The black stripe marks the negative lead (cathode). The board has a "+" next to hole for the anode.
  • Insert the LED at LED1 being cautious of its polarity just like with the LED add-on kit.
  • Insert the trim-pot at R5
  • Insert the switch at SW1
  • Insert the power jack at J32
3. Solder all components and clip the leads.
  • The solder joints for the power jack also act as mechanical fasteners so make sure you have loaded the holes up with adequate solder.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:barney_1
