Step 4Resistors and Capacitors
1. Bend and insert the resistors for R1-R4.
- R1, R2, and R4 are in the basic parts package, R3 is in the advanced parts package
- Double, and triple check the resistor color codes to ensure they match the values printed on the PCB. Replacing these with correct components later will be a major hassle.
- All of these axial capacitors are located in the basic parts kit.
- If you bent the leads at a 45 degree angle after inserting them in the board none should fall out (or move) when you flip the board over
- Make sure to double check that you soldered every one of the leads.
Caution: Installing R3 (and later U5) commits you to using the precision voltage reference provided in the advanced parts package for Analog to Digital conversions. This also precludes you from using the internal voltage reference for ADC. Read the Caution section of the Dragon Rider User's Manual if you are installing the precision reference. You can choose not to install the precision reference (and not install R3 as well), read the User's Guide and make your own decision regarding this.
Please Note
Do not install C1. It is not provided and is not necessary according to the ecros website which describes it as a "de-gliching" capacitor for the reset pin.
comments
Add Comment
Add Comment
