Introduction: Assembling the Pinwheel
Picture of Assembling the Pinwheel
The following information is a single lesson in a larger project. Find more great projects here.
Return to Previous Lesson: Writing the Code
Lesson Overview:
Now we'll actually build the pinwheel!
Step 1: Assemble the CD Hub
Picture of Assemble the CD Hub
Your Arduino kit comes with a wooden motor adapter that fits perfectly in the hole of a compact disc (CD). We call this the "CD hub." Use the diagram and instructions below to assemble this part first.
The wooden parts should also have some engraved lettering on them to make this part easier.
  1. Assemble the CD hub by snapping part C into part B. Then gently press part D onto them.
  2. Gently press the motor shaft into the star shaped hole on the back of the CD hub.
  3. Continue to the next step.
Step 2: Attach the CD
Picture of Attach the CD
Find the pre-cut paper pinwheel that comes with your kit and tape it onto the CD, using the picture below as a guide. Next you will snap this onto the CD hub to complete the whole assembly!
When you press the button on your pinwheel project, the CD will spin very rapidly. Be careful that it does not fly off! We suggest securing the CD to the CD hub with some glue.
  1. Place the paper onto the CD and secure it by taping the flaps onto the back of the disc.
  2. Attach the CD to the cross on the front of the CD hub. Use a drop of glue to hold it in place.
Step 3: Customize It!
What does the colored pattern look like when it is spinning? Try experimenting with other colors or patterns on a custom pinwheel cover. You can easily detach the current paper wheel from the CD and create your own!
Congratulations, you have completed this project!
Check out other great projects here.
About This Instructable
445views
1favorite
License:
Bio: Learn electronics and Arduino with Tinkercad Circuits!
More by circuits:IntroductionProject 15: Hacking ButtonsProject 14: Tweak the Arduino Logo
Add instructable to:
